poconosms1
- Joined
- Sep 18, 2014
- Messages
- 4
Hi All,
I'm planning on constructing either a 12x16 or 12x18 shed. I've been torn between pouring a 4 inch foundation or constructing on a foundation of stone.
My understanding is that if I use a stone foundation, i'll need to construct the shed floor on skids. I have a couple of questions.
I have a garden tractor, which when combined with all the attachments that I'll store in the shed, have a combined weight of approximately 1200 pounds. Add to that a heavy duty snow blower. the tractor is 1,000lbs with the front bucket attached (Johnny Jr)
If I run the floor joists the 12 foot run, should I use 2x6 or 2x8? I was thinking of doubling the joists in the middle, which is where the tractor would be parked.
If the skids are pressure treated, which I was thinking of staining, should the floor joists also be pressure treated? I would stain these as well.
If I construct the 12x18 shed, the rear will be approximately 10 inches from a tree. The wife doesn't want me to take it down. the Tree splits at the base into two off shoots (like a Y). Each off shoot is about 6 -7 inches diameter. Both branches lean away from my proposed shed, so there is no chance of the tree ever falling on the shed. I can't move the shed forward because the front would end up in the driveway. Does anyone see a problem with this?
