Hi all,
So I am going to move my 12x20 shed behind the garage now that the exterior build is done.
It used to be where the garage is located now, and the current home is temporary. If you look at the pics attached you can see the gravel area it is going on. The pic with the shed, you can see it is moving about 50 feet straight back, centered between the fence and the garage.
So, of course, I don't remember locations of the blocks it used to sit on. It was pretty high because it was over dirt/grass by the previous owner. It was also on a hodge podge of cinder block and wood.
I want to do this right since it is in the final home. I plan to use the 4" solid concrete block. What should the block spacing be for optimal support? Every 5 feet? There are five 4x4 runners on the 20' length. So that would 4 rows of 5. Is that overkill?
The guy that will move it (for $250) has one of those specialized trailers that it slides up on. I want to have the blocks set and/or ready to go when he goes to move it.
Thanks!
