Shed question
bmxdukie
Ontario, Canada
Hi folks!
This is more for my son. He and his girl just bought their first house. They are 21 years old and it was everything they had to get it.
However, they need some outside storage that is secure. As the place has no garage.
I was hoping someone would be able to give some suggestions for a large (8×12 at least ) shed.
You know, tips and tricks,plans. And of course suggestions on how to do it cheap!
Thanks in advance!
Kenstone1
Here in the states, the big box stores sell kits that are cheaper to build than stick building your own.
All/most of the lumber is pre-cut so there is not a lot of waste but you might need to buy shingles/roof felt/drip edge and paint.
Though I don't recommend carrying debt, you can usually charge the shed kit on a store credit card.
Edit: Rather than rely on others opinions of kits, read the reviews at Lowes/Home Depot/etc. for a real world assessment from actual owner/builders.
DGersic
DeKalb, IL
Hi folks!
Thanks in advance!
Start by checking with your local building department or code enforcement, see what you can build with a minimum of hassle. Here, that’s 12x8. Find out about permits while you’re there.
The kits are ok. I designed and built my own, because I wasn’t thrilled with the kit options. A compressor and framing gun makes it a lot easier and faster, but a hammer works and is cheaper. Having two or more people helps, especially when you get to sheathing the walls and roof.
Augus7us
Central Ohio
I think I'm going to build one to keep my mowers and yard **** out of the garage and the shop.
I haven't done any design stuff yet but I figured I'll build stick frame and pour a pad. probably run a enough electric for a light and outlet.
MushCreek
Upstate South Carolina
First, as mentioned above, make sure you can easily meet local building codes. Every place is different; only your local building department can answer that question. Where I am, it's 200 sq ft without a permit. Some places are very lax, others watch your every move.
You can buy a basic framing book and design and build the shed you want. There are a few basic framing rules, such as stud spacing, top and bottom plates, framing openings, and roof framing. You can have exactly what you want, and it can be a fun little project.
You didn't say whether you're going to build this, or the kids. Get them involved! Ideally, they should build it, with some help and guidance. IMHO, young people today need to put the electronics down once in a while and get their hands dirty. I'm not a pro, but I can build and finish a shed in a couple weekends; faster with a helper.
6768rogues
Western NY
Here it is 100 square feet or smaller without a permit. No idea what is required in the over regulated land to the north.
couch67
Ontario Canada
BMX, 8x12 is a good size and makes best use of material. That should be the outside dim. so your sheathing fits.
I 'renovated' an older shed on my property that measured 12'wide x 9'deep. Link in my signature. I think this orientation (door on the wide side) is good for a small shed, there is lots of room to either side of the door, so you are not constantly moving **** to get to what you want.
couch
DieselNut88
Northern,IL
I built a 150 sq ft shed last fall. Concrete block foundation. 12/12 roof pitch for storage attic. Vinyl siding and overhead door. Cost me about 4k and i still may finish the interior and run electric. Those tuff sheds from HD are overpriced junk imo. Build it as big as allowed without a permit. Im already filling mine up fast.
kbs2244
I would recommend a "How to Build a Shed" book from the local big box.
It will give you lots of styles to pick from and build instructions.
bmxdukie
Ontario, Canada
Thanks for the great info..
I'm quite handy. But the kids are paying for and building it.
I like the idea of the doors on the long side for sure.
He wants a tall shed that he can put a small storage loft in.
And Cobbler, yes in our area it 105sq ft as well. I think he would like twice that.
I mentioned to him that maybe the local demolition guy might have used doors etc.
Or he coukd trade his services ( he is a hvac aprentice and has all his gas tickets) to other trades.
meboatermike
Southern Maine
If he wants one bigger than just pull a "permit". There is no such thing as too big a shed :bowdown: Believe me a persons stuff will expand to fill the space with no problem (I know from 40 yrs., experience at the same address) :shocking: A bunkhouse, 2 sheds, and an old inadequate 1 car wooden floored garage that has not housed any vehicles since a 76 Civic and a Subaru Brat bit the dust, they were shoehorned in and the floor is not vehicle safe now but fine for storage. I also have a freestanding 3'x6'x4' roofed box for all oils, gas, acetone etc. and a fabric/tarped one car for a boat, lawnmower and scooter etc. Really need to build a real garage for the vehicles now
Miss the Pontiacs
Saskatchewan Canada
Keep an eye on CL...I see them for free every once in awhile.
Brian
X2. Kijiji should work in your area. Or just google free shed in your area. There are so many of these sites now. Too bad you aren’t in our area. We will have to move a metal shed to make room for some future construction.
Kenstone1
Just to expand on my previous Kit recommendation.
I have added windows to my sheds for light inside, and mounted them high (transom) for privacy.
Search ebay/amazon for shed windows or playhouse windows and you'll see narrow windows, both single and double hung, some with screens.
Narrow enough to fit between 16" OC studs so no extra framing to install, with some cheaper than $25 each with free shipping.
https://www.ebay.com/sch/i.html?_fr...&_odkw=shed++playhouse+windows&LH_TitleDesc=0
Worked for me,
Miss the Pontiacs
Saskatchewan Canada
Don’t know if this would work, but just might. A buddy of mine had a small single garage in decent shape. He wanted to build something about 2-3 times bigger. Put an add in the paper, that it was free for the taking. Some guys showed up constructed some cross beams. Jacked it up backed in a flat deck truck. Pulled out the blocking. Drove it to its new location. No mess, speedy removal, results my buddy having a big grin on his face.:beer:
LS6 Tommy
Northern NJ
Check with your AHJ about the power & light. In some towns that makes it living space and your taxes will go up.
Bmxdukie, our max size without a permit is 100 sq ft, so I have a 12' x 8'. It's a Quaker/saltbox style because of how it fits in the yard, 4" x 4" pt runners, 16" on center pt studs, vinyl siding, two working vinyl windows and double fiberglass doors centered on the long wall under the soffit. A barn style shed offers the best overhead storage, but may limit you to having the doors on the short wall. I'm not a very good carpenter, so it was bought as a package form a local dealer and assembled on site for less than $3k.
Tommy
