LGaston
I just bought a house and it came with a 12x20 shed. It's a nicer quality unit they built somewhere else and then delivered. Normal 2x4 construction, 16" on center with a big roll up door. (like you would find at a self storage place)
The entire thing is sealed, except for the ridge vent on the roof. There is about a 2" gap in the sheathing inside, and some kind of vent under the asphalt shingles. (not sure what it's called) There are no vents in the eaves or anywhere else.
I'm thinking about plugging this ridge vent with spray foam, which would let me then install a filtered power fan to use if the air is either too hot or too humid, along with a small controlled exit vent. It could easily be attached to a thermostat and humidistat. This way the shed isn't always "breathing", and the air could be run through a simple filter easily. Pollen is killer here for a few weeks/year. I could also run a dehumidifier this way.
Also, I want to install a through wall 25,000 BTU air conditioner (already have it) so I can cool the space quickly without always keeping it cool, and a small heater for the winter. (want to keep it above freezing on cold nights) I feel like both of these would work better without the current ridge vent.
Does this sound like a good idea? I'm not going to insulate anything, I just want it sealed.
