Hi all, was hoping for some input or tips regarding roofing. It's a shed but will also be used for a workshop. Will likely be heated as needed (not permanently heated). This will be for an 8x12 with a 7-8/12 pitch which I understand can be a little steep on a smaller roof.
So far general info says metal is more expensive than shingles but it seems around the same to me. Bundles of shingles (3 to a sq - just under 33sq ft a bundle) are around $25. I can get imperial rib steel sheets 3ft wide x 12ft for just under $25. To account for a slight overhang on a gable roof at the eaves and projection past the front and rear, 5 sheets of steel is $125. 6 bundles of shingles is $150 (3-tab, not architectural or anything fancy). Maybe a 7th bundle for starter row and ridge cap.
I'm thinking steel will be easier to put up but can't seem to find any consensus on what method provides a leak free roof. That's my biggest concern. I've done rough steel roofs on pole barns and stuff and they usually leak due to using second hand sheets or whatever fasteners were on hand. (aka, not the 'right' way).
Was planning on 6ft long rafters of 2x6, held with osb plates at the peak and no ridge board spaced 24" oc. Should I put down osb sheathing on the rafters, cover with roofing paper, add purlins and attaching steel panels to this? Should I put the purlins down first, then the osb, covered with roofing paper and the steel sheets directly on top? Should I forego the osb and just put bare purlins and steel (like a polebarn) and roll the dice with condensation issues? Or just scratch the steel all together and go with shingles?
My other issue is this - the steel is very limited in my area. I have choices of plain corrugated which I'm concerned will rust prematurely. Or galvalume type imperial rib painted (preferred). I don't seem to have access to all the nifty pieces that help complete a steel roof, like ridge caps and fascia trim pieces I've seen that cover the edges of the steel and direct any water/snow back onto the roof and down to the eaves. The only ridge cap they seem to have is a rounded top with a 1.5" radius which looks to me like a pain in the **** to seal at the ends of the ridge. I have a local farm type store with some steel, or I have the orange or blue big box stores which have very little options in stock. Most everything is mail order from metal sales or some place and it's like a month out. I want this thing up and done in the next week, not be trying to roof on halloween.
How have you guys done your roofs? For those who have done steel panel, how did you do it so it doesn't leak or drip condensation? Out buildings it's acceptable to stop 'most' of the water and a few drips aren't a big deal but I'd prefer a place for my tools to be water tight. Thanks.
