psychob0b1977
Hi all,
I have an 8x20 shed that I use as a workshop of sorts. I currently use extension cords for power, but I want to run electric out there for ease of use.
I have all the materials needed to run a 20amp sub panel.
My question involves how many circuits can I run on the 20amp sub panel? My plan is to have a 110v 20 amp circuit for outlets in the shop for things like saws and drills, only used one at a time or maybe 2 at a time if a buddy is helping. A 110v 15amp circuit to run lighting, 4 64 watt fixtures. that totals just under 2.5 amps in lights. but I'm planning on 5amps for lighting incase I want to run a drop light at the same time. That totals 25 amps. I am thinking of purchasing a 60 gallon air compressor that uses a 220v 15amp circuit. Would all if that be safe to run on a 20 amp sub panel? Our will I have to run a separate 220v run when I get the air compressor?
Thanks in advance!
Thanks in advance!
