sheet metal brake stand
mikegt4
sw ohio
I have a Grizzly 48" sheet metal brake that has been sitting in the basement for some time and I finally decided to make a stand for it. Having been retired for 8 years I no longer have access to any brakes to get a feel for a height that feels comfortable. Any ideas for a good working height from the floor to the platen/hinge for someone of average height?
mbatarga
GA
I'd suggest elbow height when your forearms are out at 90 in front of you would be a good start.
rsanter
visalia ca
I used two of those cheap/shorter homeowner grade toolboxes bolted side by side.
Worked great
Jim Stabe
San Diego, Ca
I made a stand with locking casters so I could move it around the shop. The bar in front swings down so you can stand on it and keep the stand from tipping over or moving around when you pull up on the handles to bend metal.
Dumber than lumber
You might get an old Black & Decker Workmate. Bolt your brake to a base made of 2 by lumber. Then clamp the base in the workmate.
NUTTSGT
Northern Central Ohio
Have you started on it Mike ?
I have a 36" Black Bull brake from TSC. I can go out and take a measurement and tell you what height it is.
Highland
Oklahoma
I would want the actual work surface (in the case of a brake the top of the folding leaf) to be between belt buckle and elbow height. Adjust the stand as necessary.
mrobins297aaa
south east michigan
the top of the folding leaf on my brake is at 38" from the floor.
lis2323
Mine vary from 34-40 inches.
sberry
Brethren, Michigan
That is some nice stuff there, nice scale. Nice for custom and repair. I worked in a place had 2 shop beside each other. Both had shear brakes. I really liked the older slower so much better for 1 off and repairs, manual can be good, gives a guy a little time to think and blink. Especially for big sheet longer bends where it can really fly.
The mag is interesting, looks like a guy could express some imagination, nice for pans, could even finger some on another machine and finish off with it?
lis2323
Exactly! The brake has WAY more capabilities than I can even begin to imagine.
mikegt4
sw ohio
I decided on 38" which felt right to me. Actually it is going to be a low cabinet that will hold my meager supply of sheet metal while serving as the mount for the brake. The cabinet is 22" front to back with the brake at the front edge. The project has been on hold while some friends are in town from California, he almost had an ****** while filling up with $1.59/gal. gas.
Back in the 1970's I made an open front bench that held a roll of fiberglass mat that dispensed out the front like aluminum foil or plastic food wrap. It kept the mat front getting contaminated with leaves and dirt (37' sailboat project) and let me roll out as much as I needed. Still have it today and I am just making a lower version.
