Sheet Metal Punch
metaldad
nw indiana
i have a few places, on the my houses' flashing, i'd like to join 2 pieces of tin, without a screw or rivet. i don't want to perforate either/ both pieces.
on a diy store bought sheet metal fitting, you can see (4) 3/16 punches / divots that hold this side of the tee together.
malco's site, doesnt show a tool that does that?
coupla union tinners i asked, stated its a shop tool. not a plier type device, like a whitney, which i tried. didnt work.
although thinking about it, if i had a spare die, fill it almost to the top with a solder, and the punch, grind down its dimple.
whaddya think?
whateg01
doo dah, kansas, usa
Without clearance, a punch would shear the edges before it passes the upper edge of the die. The punch needs to be smaller by 2x the combined thickness of the metal.
matthew
Galvanizing acts as a sacrificial anode - the zinc also protects areas where coverage is poor. Cars are not galvanized. Galvanneal (which has been annealed to form a zinc iron alloy on the surface rather than pure zinc) is better able to be painted over, and is good but less corrosion resistant than galvanized if not painted.
Toggle locks form a mushroom shaped head. The tool is more complicated than just a punch, to flare out the area. I don’t quite get why not use a pop rivet - it will have similar clearance required and be pretty functionally equivalent.
metaldad
nw indiana
rivets leak. screws leak. no clearance, clarance
galvanized spray (i dont know why id ever use it in this case) is the wrong color
no velding, its on flashing already installed on the house. and its 30 gage. thin aluminum.
i was able to make a bigger piece, bent a 90 on 1 side, and slid it under the siding
thanks for the replies.
i would unnerstand that a hand held plier type device is unobtainable
always interesting how a thread weaves
matthew
There’s a lot of bad pop rivets out there. Some higher quality ones do exist.
Although I’d actually be more worried about moisture from the overlap of the two materials (I want to say capillary action, but it’s a different word I’m looking for) than the rivet.
I’d definitely make a test coupon before using button punches on aluminum. Can be less ductile than steel and have issues with cracking and tearing.
Jim greengo
Behind my house
Art
Maybe you could have mentioned the part about it being aluminum instead of galvanized tin like normal flashing in the beginning of the story?
metaldad
nw indiana
Art
i see i wrote tin.
whaddi know about sheet metal? im a fitter
aluminum, steel, same ****, break out the band aids, i see blood in my future.
my bad
