Bigrhamr
Does it matter which way you orient sheetrock across the studs? On vertical stud walls I usually see it laid horizontal so the long axis crosses the studs.
I'm getting ready to rock my office/showroom walls, they are just over 10' tall and the framing is horizontal between posts. If I was to use 4' x 12' sheets and put them up vertically it would substantially reduce the amount of seams and taping. Is there a right and wrong way here or just whatever is easiest for the situation?
Thanks!
Thanks!
