Sheetrock Lift
rakane
Warren, Oregon
How well would a sheetrock lift work for the second 8' sheathing of 7/16 OSB? I'm doing it alone so I'm looking for a way to lift it, catch the edge of the bottom piece and fix in place. a80e95c68534988425406c546ee0879f.jpga5accd68fc6cc7d8662119b593a7a86b.jpg
Meanwhile is a 30' Grady White.
Miss the Pontiacs
Saskatchewan Canada
At the moment our Princess Auto has the Metaltech drywall hoist on special for $220.They refer to it as a 11' drywall hoist holding panels up to 4X16' with a capacity of 150 pounds.
I imagine the one you are looking at is similar so should do the trick.
I also have noticed that guys that buy these type of items rent them out after use to cover off the purchase price.
vavet
Ashland, VA
Check craigslist. They come up frequently here. I had to search to get mine because I needed to go higher than 11 feet for my garage ceiling.
Leaflessshadetree
Don't ask.
It works great for that but you work from the top down so what you refer to as the 2nd 8ft should probably be the 1st 8 ft. (Also I hang wall material horizontally so doing it vertically make it more difficult).
jeffmattero76
For sheetrock, I agree that you should start at the top sheet and work down. However, for OSB, I don't see why it would matter.
Sent from my SM-G530T using Tapatalk
R
rakane
Warren, Oregon
That answered my questions. Thanks for posting.
matt_i
If you're talking wall sheating I think there's a better way.
Screw a 2x4 to the wall, large flat on the wall, top edge flush with your existing OSB edge, use only 2 torx or deck screws. Now screw a 1x2 to the 2x4, flat-on-flat, push the top edge of the 1x approx 1/4" above the 2x4s edge. Now you have a place to lift and rest the sheet, it only needs 1 screw thru the OSB to hold it once set. Then you can zip in the rest.
The problem I had with the lift hanging drywall, is lift is it can't get closer than about 16" to the wall no matter how you twist the 3 casters. That's a long way to launch the sheet if you ask me. Also with a 12' sheet of 5/8" (I know its not drywall) its heavily unbalanced until the sheet is flipped up flat and I think the crude telescoping center will grind to a bind with the sheet off-center and it being loaded on a cantilever.
The Cobbler
the reason for hanging the top sheets first is so you can nicely **** it to to the ceiling .
unless you're planning a trim pc at the top I would hang the tops first . even then I would do the top sheets first.but that's me
R
rakane
Warren, Oregon
The shop will have an open ceiling so top first or bottom is not a big deal. I can start low until I figure out how to do the higher part without injury or failure.
