sheetrock question
fury9
Mchenry, IlLaHnoYs
walls, normally 1/2 inch unless it needs to be fire rated (think furnace room)then it's 5/8, ceiling 5/8 always or you will end up with a wavy ceiling. Garage? I'd do 5/8
Trevor454
You can get special 1/2" for ceilings with 24" centers that has fibreglass strands which will not sag like normal 1/2" wall drywall.
readhead
Durango, Co.
Where is the drywall being installed? Is it adjoining the house? Makes a differance in the material you use.
readhead
Durango, Co.
I would be inclined to use 5/8" regular for everything. I think it would be a little more durable for this aplication.
Trey T
Houston, TX
My home uses 1/2" for wall and ceiling and it was built in the 1970s. Why would I want to use heavier/thicker board on ceiling?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Around here, any house built uses 1/2" for everything. Walls and ceiling both. You won't have a wavy ceiling if you go across the rafters instead of with the rafters.
ShumanSS6.0
Minnesota
What he said. Also, make sure you have 5 rows of 5 screws per panel (on a 4x8 sheet) and drive at least 1" of the screw into the stud (1.5" screws min if going with the 1/2" drywall).
Trey T
Houston, TX
^Sag potential? I highly doubt that because you have to fight the weight. It's not like the board is designed in different shape (engineering term, moment of inertia). Or unless you spaced your joist or rafter wider than typical, then you will see sag, assumed you fastened it properly.
Fire suppression: How significant for residential home?
csp
Franktown, CO
5/8" is stiffer than 1/2" board.
Apparently it's very significant since it's code that Type X 5/8" is installed between garage space and living space. Code is for 20 minutes of fire and 5/8" meets that requirement.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Here's a question for the drywall experts I'd like to know an answer on......If a house by code is supposed to have 5/8" drywall to help slow a fire, why is in not required to use FIREPROOF drywall instead of just going an 1/8" thicker and using a fire rated drywall?
To be honest, I never even heard of fireproof drywall until the other day.
Trey T
Houston, TX
What you're forgetting is the weight. Look at it this way, you don't engineer a bridge w/o considering its own weight as a mode for failure.
I would be careful about using the term "fireproof" because I don't think any gypsum board maker advertise their product to be "fireproof", just more "fire resistant" depending on the thickness.
csp
Franktown, CO
No, I'm not forgetting the additional weight. It is stiffer even with the additional weight. Better?
It's not like you're going over a subject that's never been considered before. It's been proven that 5/8 resists sagging better than 1/2" over a given span between joists.
scottydosnntkno
exactly. As an architect, I am very familiar with codes and such.
in MANY cities/states it is code to use 5/8" on the ceiling, mainly for better fire resistance but it also looks better because with many new houses using 24" spacing with I-joists, 1/2" drywall will sag.
This is nothing new, and you're views while relevant, still don't change the fact that most houses have 5/8" ceilings.
Look at 92-5/8" studs at the lumber yard. 92-5/8" stud + 4.5" (double top + bottom plate) leaves 8'-1-1/8" floor to bottom of joist. Subtract 5/8" drywall ceiling and 1/2" floor thickness leaves you with 8' clear floor height.
