Shelving for metal building
2slow95vert
FYI if you have a costco nearby they sell similar shelving much cheaper than that. Also If you can wait, walmart has had Edsal sheliving very similar to that for $99. I've bought several of them. Nice but def not the same league as pallet rack.
driftpin
I have the Whirlpool Corporation Gladiator shelves like that & I believe the Costco & Wallyworld products are thinner-gauge. Compare the load rating, the Gladiator is 2000 lbs equally-distributed per shelf for the long unit, they also come in shorter lengths, too to fit your space.
i narrowed the depth to 13" to fit the space on the side of my garage door return, I needed to be able to store my record collection (2000+) along the wall in that narrow space. I used a combination of aluminium square stock and PT square wood stock ripped to size, and 1/4" hex machine screws & flat washers to bolt together the shortened steel end framing, and the individual shelf supports that help hold the load in the middle of the wire shelving. Depending on the length of the shelf, there may be either two or three of those "clip-in" reinforcements per shelf.
The shallower shelves fit neatly into my limited side wall return space, and allov me to park my GMC truck in the garage if I need to, and still be able to exit the truck.
I thought of putting masonite on the wire shelf surface, but the load there is pretty much permanent. If you were going to be placing & removing things frequently in the shelf, then a solid surface on top of the wire rack, instead of the bare wire rack might work for you.
If you put a mezzanine or loft above the shelves, these are a good height.
A tip, I put the first shelf maybe 6" above grade so I can slip under the shelf things like floor jacks, cherry pickers, spare lolly columns, etc, and it also makes it easier to keep clean, or to retrieve something that falls to the floor. I usually use a handheld blower to 'sweep' under the shelves every couple of weeks.
ptgarcia
Alta Loma, CA
My local Sam's usually has the Muscle Rack brand in their store. I ended up buying a couple of the Edsal brand from Lowe's or Home Depot for less money. Those and Gladiator are virtually the same and share the 2000lb per shelf load rating. The Gladiator look like a tool free assembly but you pay more for that convenience.
Slednut
Washington state
I just purchased one of those at Costco for $129 a month ago, needed it for storing project car parts. I don't see them on Costco's web site though.
The wire shelf inserts aren’t as strong as they look.
Jeff95TA
Pittsburgh, PA
Mueller building being finished up. 30x40x12. Looking for freestanding shelf ideas. I really like pallet rack shelving, but these seem like a good deal:
https://www.lowes.com/pd/Gladiator-...D-Steel-Freestanding-Shelving-Unit/1000003004
Does anybody have any ideas on how to put doors and sides on them? Would really be interested in enclosing them when not in use.
If you decide to go with that, check out Sears. Currently $169, was $149 a few weeks ago.
http://www.sears.com/gladiator-77in...=11042411&utm_medium=2470763_6147012_11042411
