sherman and williams macropoxy 646
beefsteak74
next to house
I've used this several times before but this time I screwed up.
I did some touch up after drying, but I used left over base with no epoxy in it.
Now I have sticky spots in my drive port that don't want to dry.
I'm going to redo it.
Will the spots eventually dry or is there a chemical I should use to remove the sticky spots of paint?
I have about twelve spots three inches in diameter.
thanks
kaymccampbell
Upstate New York
Did you try brushing on a bit of the second part? I've been successful doing that where the owner oopsed and made a sticky mess on a whole porch floor.
beefsteak74
next to house
I will scrape it off, then use a high speed disk sander, eventually.
I was just wondering if the spots would dry up first so I won't keep gumming up my sanding disks. But they will have to be sanded. They look like ****.
