cdottrot
Ok, figured I'd make this a two-part question:
Part1
I got my new man-door mounted last night, door swings, closes, shuts/opens just fine. I used a rather large amount of shims. Bad thing?
Part2
In the process of replacing the man-door, I had to replace some of the rotten framing. I poked with a screwdriver until the wood seemed 'normal', then used the sawzall to cut out the bad bit. Replaced with 2x4 PT, white silicone caulk between concrete and PT. The bottom plates are not really secured by anything beyond pressure and on the right, the rusty anchor.
Question: Is the blocking I used to attach back into the framing okay?
I picked up some shells and nails for the ram-set, so I'll try and get some of those into the plates.
Part1
Part2
