Shingling round roof barn
Dagny
Northern Wi.
Did half of it 16 years ago with architectural shingles. They held up well not sure which model but know the package was pink. either oakridge or duration.
how come when you research on line all you find is all shingles ****.
thoughts?
D
Dagny
Northern Wi.
They are about the same price. I am not sold on the steel with the exposed fasteners. That little rubber washer will fail eventually as the lead headed nails have on two of my other buildings.
meboatermike
Southern Maine
Unfortunately the quality of shingles has gone down quite a bit over the last couple decades or more due to changing of material inputs. Read the warranty carefully that they give as they are much less advantageous then they perhaps seem to be at 1st blush. :(
Bretny
Dutchess county NY
Im not really sure what he means by round roof but im prety sure your not going to be putting metal roofing on anything round.
Showkey
"MEMBER EMERITUS"
Wausau WI
Metal solves nothing...........there’s still all sorts of issues with quality of metal, coatings, install, surface prep/material ...........not to mention cost.
Metal Issues? like waves, ripples, rust, fade, leaks, fastener, snow and ice control
D
Dagny
Northern Wi.
My computer skills are lacking for sure when it comes to pictures. I could lay 4 square of shingles in the time it would take to get a picture on here. but I will try.
Handyfarmer
in the high plains of Colorado
Look at GAF Timberline series.
on the timber line shingles do not work well on steep or vertical surfaces,
I used them on the eves of my house, and I think one would have to take the tube of roof tar, and glue them down as one went, or I took small wood shingle nails and tacked the edges down as they would never seal or glue them selves down, From there directions
MANSARD AND STEEP SLOPE APPLICATIONS: For roof slopes greater than 21" per foot (1750mm/m), shingle must be hand sealed. DO NOT
use on vertical side walls.
noslin
look at malarkey shingles. they have a new asphalt they are using. when you look at asphalt thats been used in all shingle manufactures for years its really interesting how its made. with conventional asphalt for shingles they force air through it to get the melting temp where they want it. meaning, the asphalt is very viscous and softening point is low. so they force the air into it which raises its softening point. it basically ages the asphalt.
malarkey's new asphalt is not oxygenated, they actually use a lot of recycled rubber, carbon black they get out tires, etc so it doesnt have the air forced through it like conventional asphalt.
what this does is grabs the granule better where as the traditional asphalt is already hard or harder. it doesnt grab the granules as well. then years down the road when you see all the granule in your gutter you wont see that with the new asphalt like malarkey has.
also, their new granules are smog eating granules. 3m makes this for them. its kind of proprietery deal for them for a while.
up untill a few years ago all shingles were 30, 40, 50 year.. i think GAF changed the market and made them all 'lifetime' doing away in the market as 30,40, 50 year. also, shingles were reference by weight, well GAF doesnt even list a weight. There timberlines weight about 200lbs a square if that. certainteeds is about 245, untill malarkey went to the new NEx gen asphalt thier highlander weighed 247, now its 23x lbs. Pabco makes a real nice shingle and is heavy. pabco probably has the best warranty in the market too but malarkey will match anyones warranty if you are really concerned about it. warranties are written for the manufacture, not the home owner.
you can install a curved roofing panel that is not exposed fastened. look at any mini-batten panel. I know for installers, they can get an on-sight tool to curve the panels if need be and manufactures such as AEP (which is ASC) will curve them for you in the shop and send out if you get them the radius. you can also use a 2" mechanically seamed panel too. concerning the oil canning, all panels will oil can ecspecially if your using 26ga or less. never use 29ga unles you just dont care. to get away from oil canning go thicker and narrower on the panel, eg 22ga and 12". all panel manufactures now days give you a paper and some make you sign stating your aware of the oil canning and they recommend striations or minor ribs.
I push the mouse around a computer 8-10 hrs a day as a commercial roofing estimator, i dont deal much with residential although i take care of all the residential metal roof estimates. i can get technical info for you if you need any help. im not an expert by any means but im sure there is a few running around here :D
as with anything, need to pay attention to the details or youll get screwed. doesnt matter if its comp, metal, tile, or whatever.
bpjr
Florida east coast
If not where hurricanes roam a shingle roof should be fine. Architectural shingles resist hurricanes better here in Florida...when shingles and tiles are flying, metal isn't. Cheap 20 yr shingles work but they typically have skimpy glue lines and don't weather high winds as well.
Use "peel and stick" under layment for best water proofing under any type roof. Some metal roof panel mfgs spec to put their product over a water proof barrier which is the peel and stick. Its basically self sealing around fastener penetrations and if a shingle flys you will have minimal leaks, if any at all.
Metal roofs have come a long way since the days of nails with rubber washers. Neoprene washers under a fully hooded one piece head gives way better results. Combine this with peel and stick and leaks are rare with exposed fasteners.
polizei1
Cinci, OH
Ah, didn't know that, I think mine is a 6 or 8/12 pitch.
