Hi all,
I ordered a 30' X 50' X 10' pole barn kit with 8" X 8" posts. Had an old friend (not very close) doing some work around the house and he offered to install it for me. He has is own business (long time) and I thought he knew what he was doing, but that turned out to be a judgement error. The barn is finished to the point that one half of the roof is installed. The other half has the purlins installed. This is the point where I found time (and my 100' tape) and started measuring his work. After measuring, I stopped work and we parted ways. Here is what I found:
Now that I stopped work, I need to decide to just live with this and install the other half of the roof myself. To a casual eye, the building actually looks pretty good. I plan to use the barn for trailer/boat/tractor storage and plan to build a steel garage next year for my real shop.
Or should I tear off the half roof, remove all purlins, square it up, and reinstall everything. I live in Florida and is easy digging sand. Plus, he only used 1 60 lb. bag of concrete, which will work in my favor should I go this route. I would leave the posts mated with the rafter and move them into position as a pair and brace them. Once all are in place, fill with 3 80 lb. bags each post. I see this as many hours of pretty hard work on my pre-retirement body. I have a small tractor to help me, and I would rent a lift bucket to remove the roof and purlins, then rent the lift again when time to re-install. I am used to doing projects like by myself, and have built several smaller pole buildings in the past. Also, I may add siding in the future and the squareness issue will come up again if I decide to add siding.
I am afraid if I leave it that I would notice these issues every time I use the barn and it would have negative mojo - for lack of a better description. I see the rebuild taking about 4 weekends and a few days off work here and there.
Any advice? I was prepared to start tearing down today but decided to ask out here for any input before I committed. I am kicking myself for letting it get to this point and not measuring earlier, but I have pretty aggressive job schedule. He had 2 other guys and worked 4 days to the point I stopped the work. He thought I was being a picky perfectionist and I told him all I wanted was reasonably square and no leaks. I have never seen a building this far out of square.
- The building is out of square by 11" on the diagonal.
- 13 of the 14 posts are out of plumb. Several are out over 1/4" per foot.
- 26 gauge Galvalume roof - the half that he installed has 80+ screw "misses" where the screw missed the purlin and the threads are exposed. Also has 20 or 30 complete misses where the screw was removed and you can see daylight.
- One of the steel rafters seems to have taken the brunt of the squareness issue. The peak is about 11" off center and the rafter is noticeably disformed. One other rafter is off center about 2" or 3".
- He only used 1 60 pound bag of Sakrete per post (8" X 8").
- The purlins have numerous gaps between ends ranging from 1" to 4" to make up for the out of square issue.
