shoe molding - cope or mitre?
Higgins
Shepheardsville, KY
And once it is coped, you can use some fine sandpaper on the coped piece to fine tune in the curvature and it will look great !!!!
AL
quattro_sinko
Upstate NY
Not recommending anyone try from a liability standpoint, but safely coping with a scroll blade in a jig-saw is the bee's knees. About as quick and clean as you can get in one shot, with a little practice.
Bert_
NW Iowa
I find even an decent/average coped joint looks better than anything but the tightnest mitered joint.
billconner
Thousand Islands NYS
Thanks. Guessed this. Coping saw, Dremel tool with the tiny drum, or oscillating tool?
3 inside corners, 3 outside, and 6 ends.
Thinking I'll just shape end, not try to mitre a little return. This is small shoe, barely 1/2 x 3/4, and not bothered by the maple end grain.
mike93lx
Richmond, VA
i wouldn't use an angle grinder on something that small, but i've used one on larger trim with decent results.
i'd probably just grab my coping saw, a file and some sandpaper, but the dremel likely gets it done faster.
rcbk00
All inside corners on baseboard, shoe, chair rail, and crown should get coped. For shoe, I use a jigsaw to cut away the majority of the waste. That's followed up with a razor knife and/or a piece of sandpaper shaped into a roll to fine tune the edge. On trim larger than shoe, I'll often use my m12 right angle die grinder with a 2" roloc sanding disk to fine tune or back bevel.
56Mark
Fall Branch, TN
Last year I coped a bunch of shoe using a cordless cutoff tool. Then I took some medium grit sand paper and glued it on to piece of the shoe to use as a profile sander to sand right up to the mitered edge. (I think it was sticky backed sandpaper).
billconner
Done. Coping saw and dowel with sandpaper. For the two I needed (I know I said 3 but one was behind a baseboard radiator) it was easy.
And hurrah for brad nailer. Last time I used a finish nailer and had to set and putty nails. Not now.
Lots of good help on this one. Thank you!!!!
