Hevnbnd
This may not have the detail you are looking for, but it is the Index for an aborted book I was working on:
1. Planning utilization of floor space
A. Flat floor area – suspension and lighting adjustments
B. Tear down area / Dirty Bench
C. Welding Area
D. Clean bench / Assembly area
E. Storage of parts
F. Storage of spares
G. Storage of material (tape, hardware, cleaners, waxes, polishes, oil, ATF)
2. Design Technique Options
A. Grid paper
B. Power Point
C. eXcel
D. Roger Los’s software
E. Garage Journal option (3 dimensional)
F. Web sites with planners
3. Water
A. Deep / Slop Sink
B. Bathroom: Toilet / Shower / Sink
C. Washer hook-up
D. Exterior
E. Drains
4. Pouring the Floor
A. Prepare the base
B. Install vapor barrier
C. Insulate before the pour
D. Thickness of concrete
.....a. 4” thick
.....b. 6” thick
E. Floor thickness under lifts
F. Sloped for drainage, but flat where needed
G. Reinforcement
H. Rebar
.....a. thickness of the bar
.....b. denseness of the grid pattern
.....c. Fibers in concrete
5. Doors
A. Vehicle Doors
.....a. Double-wide vs. single (width)
.....b. Height
.....c. Overhead
..........i. parallel to the floor
..........ii. tracks the slope of the ceiling
.....d. Roll up vs Paneled
.....e. Carriage doors
.....f. Insulated
B. Man Doors
.....a. Auto closing
.....b. Crash bar
6. Sequencing of machines and appliances
A. Cleaning
.....a. Wire wheel
.....b. Parts washer
.....c. Blast cabinet
B. Polishing
.....a. Buffers
.....b. Polishers
C. Heat
.....a. Welders
..........i. TIG
..........ii. MIG
.....b. Plasma cutters
D. Specialized
.....a. Brake
.....b. English wheel
.....c. Lathe
.....d. Drill press
.....e. 20-ton Hydraulic press
E. Workbenches
.....a. Mobile
.....b. Fixed
.....c. Dimension
..........i. Height
..........ii. Depth
..........iii. Length
.....d. Material of top
..........i. Wood
............1. Old bowling alley
..........ii. Metal
............1. Stainless steel
..........iii. Laminate
.....e. Overhead shelf
..........i. Height
..........ii. Stability
..........iii. Doors vs open shelving
.....f. Lighting
F. Engine hoist
.....a. Mobile
.....b. Fixed
G. Lifts
.....a. 2-post
.....b. 4-post
.....c. Portable scissors
.....d. Pits
..........i. Fall in
..........ii. Capture basin for heavier-than-air fumes
7. Planning utilization of wall space
A. Shelves
B. Cabinets
C. On vs. above the floor
D. Material; Wood / Metal / Plastic
8. Electrical distribution
A. Let’s get technical
.....a. Amps
.....b. Wire gauge
.....c. Grounded outlets
B. 110 outlets
.....a. Multiple circuits
......b. Color marking
......c. Height above floor
.....d. In the ceiling
..........I. garage door opener
..........II. lift
..........III. drop light
C. 220 outlets
.....a. Welders
.....c. Oven for power coating
.....d. Spares
D. Switches
.....a. Master switch
.....b. Banks of lighting
.....c. Mixed incandescent with either fluorescent or Metal Halide
E. Exterior
.....a. Safety
.....b. Motion detector
.....c. Walk way
F. Distribution panel,
.....a. Wiring
.....b. switches and outlets
.....c. removable panels above and below the distribution box
9. Lighting
.....a. Lumens
.....b. Color Rendering Index
.....c. Color Temperature
.....d. Incandescent vs. Fluorescent
.....e. Measuring brightness
B. Ceiling
.....a. Fluorescent
.....b. Halogen
.....c. Other
C. Specialized Lighting
.....a. General
.....b. Task
..........I. Workbench
..........II. Machines
.....c. Under the Lift
..........I. In-Floor
..........II. 30º up-angle low on the wall
.....d. Exterior
..........I. Safety
..........II. Motion
D. Artificial vs Natural
.....a. Window
.....b. Artificial
..........I. Windows
..........II. skylights – and leaks there from
..........III. security – another point of entry
..........IV. Natural – gable lighting???????
10. Pressurized air distribution
.....a. CFM
.....b. PSI
.....c. H/P
B. Type of compressor
.....a. Oil-less
.....b. Size of motor
.....c. Size of air tank
C. Placement of compressor
.....a. In the garage
.....b. Outside in a dedicated shed
.....c. Ease of maintenance /repair/replacement
D. Air Dryers
E. Hook-ups
F. Exterior connections
G. Material used for distribution pipes
.....a. Copper
.....b. steel
.....c. PVC
.....d.
H. Quieting the compressor
.....a. Outside
.....b. Insulated shed
.....c. Car body mounts under the feet
11. Air
A. Ventilation
.....a. Ceiling Fans
.....b. Exhaust Fans
.....c. Sky lights
B. Heating/Cooling
.....a. In-floor radiant
.....b. In-ceiling radiant
.....c. Forced air
.....d. Waste oil
.....e. A/C
C. Insulation: 2x4 vs 2x6
12. Floor covering
B. Seepage
.....a. Testing
.....b. Damages from Mold / Mildew
C. Prep
.....a. Muriatic Acid
.....b. Shot Blasting
.....c. Vacuuming
.....d. Sweeping
.....e. Mopping
D. Carpet
E. Paint
F. Tiles
.....a. Plastic
.....b. Vinyl
.....c. Italian
G. Epoxy
H. Concrete polishing
13. Tool Boxes and Chests and Carts
A. Craftsman
B. Lista
C. Snap On
D. Huffy / more / others / another
14. Hand tools
A. On a peg board
B. In a tool chest
C. On a tool cart
15. Communications
A. Telephone
B. Computer
C. Intercom to main house
D. Remote door bell
E. Sensor on drive way
16. Entertainment
A. TV
B. Stereos / Radio
C. Refrigerator
17. Decorations
A. Posters
B. Pictures
C. Wall colors / stripes / patterns
D. Trophies
E. Themes
.....a. Soda Bar / Pin Ball machines / Juke boxes
.....b. 50’s
.....c. Race
18. Security
A. Windows – natural light vs security
B. Sky light – natural light vs security
C. Crash bars on doors
D. Bars on windows
E. Alarms
F. Motion detectors
19. Safety
A. Fire extinguishers
.....a. Positioned near exits
.....b. Positioned near likely fire sources
..........I. Welders
..........II. Plasma cutters
..........III. Electrical work
..........IV. Flammable material storage
B. Smoke Alarms
.....a. But not in the welding area?
.....b. But not near vehicle exhaust
C. Exhaust fume extraction system
.....a. Running engines during tune ups
.....b. Over/Near welding area
D. Flammable storage
E. Open flames
.....a. Water heater
.....b. Garage heater
F. Part’s washers
G. Gasoline / other flammables
H. Waste oil
I. Coolant
J. Eye washing station
K. Eye Protection
L. Gloves
M. First Aid Kits
20. Miscellaneous
A. Oil disposal
B. Hand Wipe dispenser
C. Trash disposal
D. Clock – or not
E. Keeping it all clean
.....a. Floor covering
.....b. Central vacuum system
.....c. Washing it out with water hose
F. References
.....a. web sites
G. Records – tracking all the parts you removed and finding them years later
