supersaiyan93
I recently acquired a 36" drum fan for peanuts that had a few issues. Specifically, it's a FE-90D3FOL model that appears to be turn of the millenium vintage.
When I first got it, she shook like crazy, made all kinds of racket, and only runs in one speed. The mechanical issues were obvious. I split the motor and found two shot bearings. The replacements are on order. That should fix the shakes and shouts.
Now, I don't claim to be an e-lectronical genius. I could use a little help figuring out the multi-speed issue. Right now, the original switch knob is MIA and the motor is turned on by plugging it in. It only runs on high.
Attached are a few pictures showing the wiring, and also see my very crude MSPaint masterpiece showing how it's currently wired up.
So what I need to know is, what the heck kind of motor is this? What kind of selector switch do I need to replace the missing one? How do I wire this up?
Thanks guys!
Thanks guys!
Only the hole in the case where the switch once was remains. If I had to guess, the knob is what failed, prompting the previous owner to bypass it. That should mean I can fix it with a few dollar part if I can identify what the wire colors going to the motor correspond to.
If all goes well, I'll have a $260 drum fan that I'm all-in for $50 including the fan itself, a simple switch, and two cheap bearings.
