Shop heater won't fire when its below 20
JUNK-MAN
PA
So I installed this Goodman furnace in my garage this year and for some reason it will not future when its below 20 out. Every once in a while it will fire if I put a small space heater on a ladder aimed at the back (circled area). What's the matter with it and what can I do to fix it? Thanks 011727f62385b071418d426d7c703b69.jpg
Showkey
"MEMBER EMERITUS"
Wausau WI
Is the building temperature also low as in freezing ?
That appears to be a condensing furnace and should no be allowed to freeze.
What are you doing with the drain water ?
J
JUNK-MAN
PA
The garage is an unheated pole bard, here's a pic of the condensation drain.
J
JUNK-MAN
PA
It is propane and have it set to run off the size tank a gas grill uses. As I said, i have had no problems until it gets really cold.
American Locomotive
Rhode Island
The problem is almost certainly your propane tank. Those propane grill tanks cannot evaporate enough gas fast enough when it gets extremely cold out.
Adk Mike
upstate NY
You can not run a furnace like that in cold weather on a 20 pound propane tank. A propane tank vaporizes the gas much like boiling water on a stove. You are burning the vapor. When it’s cold the pressure in the tank goes way down. 28 pounds at 0. On a hot summer day it 190 or so. You need to get what the industry calls a 420 or 100 gallon tank and you’ll be fine. Mike
Adk Mike
upstate NY
A 20 pound grill tank holds 4.5 gallons at 91,400 btu’s per gallon.the tank has 411,300 BTU’s In it . If it’s a 100,000 btu furnace you can run it 4 hours. But if the tank won’t vaporize it doesn’t really matter.
yeldogt
Also -- You can't allow a high efficiency furnace to freeze ... they have water in them?
If you read the specifications ... most heaters are not designed for continuous cold weather operation. Some need return air almost 60 degrees.
