I currently live in a shop house style setup. Shop (3400 sq. ft.) was built in 1973 with living quarters (848 sq. ft.) added between 2010-2017. (Long process). The shop has a 200,000 BTU propane Modine heater in it which works fine. On top of the living quarters, still inside the shop but enclosed in a small room is the High Efficiency Guardian HVAC system and hot water heater. When I had the furnace installed, the hvac guys put air returns in 3 rooms of the living quarters and left the fresh air intake open so it just ***** air in from inside the shop. Problem is when working (painting, gas, exhaust fumes) the HVAC system will **** in that smell and bring it into the living quarters. My HVAC guys said it won't matter because with it being a "high efficiency" furnace the fresh air intake is only for the combustion chamber which is sealed separately from the air that circulates around the house.
Is my HVAC guy wrong? Should I put a pipe to the outside wall for ACTUAL fresh air rather than drawing from inside the shop. My first instinct is to obviously do that but my HVAC guy is adamant that the fresh air intake is strictly for combustion and won't effect the smell difference in the living quarters.
I am sure I left some crucial detail entirely out of the picture but if anyone has any suggestions or opinions I would really appreciate it! Can always provide more info as needed also!
