walker450
I have a 30x50x14 metal building with a 6/12 pitch roof. There is plenty of room above my two 10x10 overhead doors that would make a good loft area. I came across some I-beams and my idea has been to use the I-beams for some of the loft structure but I also want it to double as an I-beam trolley.
I plan to weld two 6" I-beams together to make the 30' span. I will then have another I-beam in the center perpendicular on top of the 30' I-beam, and a support post approximately 3' from the 30' beam. This will make the span basically 15' unsupported.
On top of the 6" beam I will put a 6" piece of open-cee and then run 6" cee from that to the wall on 2' centers and then put 4x8 tounge-and-groove plywood on top for the flooring.
One side of the 30' beam can sit on an upright beam that will be anchored into the concrete. The other side is over my walk-through door.... so my plan is to build some brackets, weld them to my uprights, and put another beam between the two uprights and then the 30' beam will sit on top of it at 90 degrees.....
I hope this makes sense... here are some pictures and my attempt at drawing the arrangement in Paint:
