scott37300
I'm looking at either buying or making(most likely) a shop press. So looking for pictures of other presses, either boughten or built to get some ideas from. The design seems pretty straight forward, some C-channel welded together, but just looking for some ideas.
And for the hydralic part I am thinking about using a 10 ton porta power ram with the hand pump, I have 3 of them that I don't use that much. Anyone see any problems with this idea?
So lets see some pics!!! Or any suggestions you have on what to include in the build or what you would change if you built your own.
Kind of shocking to the arms and wrist. The holes also tend to drift to one side because of the taper as the drill exits. It all works much better if drilled in a sturdy machine setup, or with a magnetic drill. Your selected sizes of channel would be good to use.
