Shop Project: A DoAll Work Holding Jaw
OccupantRJ
Eastern North Carolina
I use a 16 inch Do-All at work, and I sure would not want to be without that feed assist, especially on the thicker material sections. It's one of those things you have to use to appreciate it. Ap, I see you got tired of dragging your knuckles in the chips on the table during cutting. That does get your hands up a bit, doesn't it.
RJ
A
A_Pmech
IL
RJ
Yeah, dragging knuckles was getting old in a hurry. That, and it makes it a whole lot easier to get a grip on the work.
1320stang
Edmond, OK
Then I pickled the steel in Muriatic Acid to remove the mill scale:
I sure wished I had known Muratic Acid would remove mill scale prior to sand blasting over 200 letters for a church sign I'm making. :mad:
Steve from Socal
Hutchinson Ks.
RJ
That is why DoAll made these. This one has a servo feed control but they also make a simple hydraulic feed. The servo is pretty neat, if the feed pressure is too high it pushes on the lower blade guide and the servo dump pressure to the table feed.
Steve
KenS
Since there are no sprocket teeth to engage the chain on your design, versus the factory model which looks like it does engage the chain links, is there any chance of the chain slipping off?
A
A_Pmech
IL
Hi Ken,
Not really... It's possible but not likely. The sprocket teeth are mainly for use with saws that have a "steering system" built into the power feed. I don't have that, so there is no need for the work jaw to engage the chain
With larger workpieces, one simply wraps the chain around the workpiece, so I don't expect any difficulties.
bimmer1980
York, PA
Hmmm, some how I missed this thread until it was brogh up in your thread about the radius cuttter for a lathe.
Once again, some fine craftmanship!
It's also another tool to add to the list to fabricate!!
Amitygravel
Claremont Illinois
John
Your work continues to amaze me. All of the project threads of yours that I have seen are always so detailed and informative even their quality is top notch ! You should print a book of the projects you have done. Thanks for taking the time to share.
Craig
A
A_Pmech
IL
Hi bimmer,
Thank you. :)
It's a handy little devil. I use it about 75% of the time I use the saw.
Thank you, Craig. Bolster asked me to produce a PDF of the DoAll rebuild a while back and I was thinking about that last night. I have a couple more little things to do and then I'm going to finish that off and make the rebuild PDF available. :beer:
larry_g
oregon
I echo that I missed the thread first time around. Very nice work and esp the handles. I saw the first picture and first thought through my mind was that you would mill off the 'teeth' and make a replacement set to bolt or weld on.
lg
no neat sig line
