jimmy12345678
Fellow techs out there, I'm curious as to what your shop provides for you vs. what you have to provide for yourself, both tools and shop supplies (gloves, uniforms, etc.)
I've worked in three different shops so far in my career, two dealers and an independent where I'm at now, and had to provide varying amounts of tools and supplies at each one. The dealers provided gloves and uniform services, my current shop does not. At the dealer we obviously had the factory scan tools and special service tools (most of the time....), at my shop now I'm pretty much on the hook for any tools I need other than the basics (lift, brake lathe, tire machines, shop press, strut compressor, etc.) but my pay is a decent bit higher than at either dealership.
I personally HATE shop tools, because a shared tool is an abused tool. If you have no money in a tool, you're more likely to abuse it because "It's not mine!" And in a lot of shops the "shop tool" is the cheapest piece of **** the shop owner thought they could get away with (e.g. crappy HF tap and die set, torque wrenches, etc.) I'd rather invest in myself and my career vs expect the shop to provide a majority of the tools and deal with the headaches of sharing a tool with every other tech in the shop, and dealing with half working/broken or missing special tools that you're just expected to "make it work".
I'm also a big believer in the "If you borrow it three times, you need to buy your own" rule. If you've borrowed it that many times, you obviously need it enough to where buying your own would benefit you. I've seen so many guys who use the crappy broken shop tools and complain about them, but I rarely (if ever) see them investing in their own tools to do the job better. They are content to deal with half working tools because they're either too cheap to buy their own or just don't give a ****. Or borrow the same tool over and over just expecting either the shop or another tech to provide it for them, and only have the most basic of tools themselves.
So where do you guys draw the line, and how much does the shop that you work at/worked at in the past provide for you?
They had a limited range of scan tools and a few specialty tools. They didn't let us use brake clean as it was too hazardous
I missed brake clean at that job.
