I am getting ready to make the next addition to my shop...dust collection. I could use some advice.
The most consistent source of dust, and the most pressing reason for adding this feature, is the wood lathe(s). My daughter turns 3-5 days a week, and while she wears a mask, it still gets dusty, especially with sanding. Right now I have set up the shop vac to act as a dust collector, which actually works quite well. I know there are dust shields that hook up to formal dust collectors. I will likely incorporate something like that.
Other occasional dust sources vary from metal grinding, auto body sanding, wire wheeling old arn, wood working, etc. I also will rattle can spray small parts in the shop.
I have a Mini Split heat pump heating and cooling in my shop, and it likes to pretend it is an air cleaner for the shop. I usually turn it off when doing dusty work.
I have only 30 amp service to my shop. In the 5 years that I have worked out there, I have only blown the main breaker 3 times. The last two happened when my daughter was turning on the Yates J170, had the shop van running, heat on, and I tried using the band saw. The shop vac seemed to be the variable, because I usually run anything I want while she's working and we don't have issues.
I am limited on shop space, so I want to ad an addition of the outside wall of the shop right behind the lathe area. A small closet type room. My question is this:
Do I put a shop vac or a true dust collector in that closet? Which system would give me more power with less amp draw? I don't typically make that must saw dust, more a general room mess. I am considering adding a room air cleaner too, if they work as advertised. Most of my tools are vintage arn, and don't have true dust collection hook ups.
Sorry for the long rambling post. Just wanted to paint a somewhat detailed picture of what I have and what I need.
Thanks
Dave
Thanks
Dave
