Shopvac bag slipping off...
tlmartin84
West Virginia
My bags slip off of the inlet after they collect a bit of dust on my 20 gallon. I guess they get sucked off when the bag clogs...
Regardless is there a way or an adapter to keep them on? I looked it over and it doesn't appear like I can even get a zip tie around it.
T
tlmartin84
West Virginia
Bag and filter FTW. Filters last a long time and the exhaust air is clean.
@tlmartin84 maybe a different brand? I have never had a bag slip off. Some shop vacs have a slot that the cardboard piece slips into, but my main vac just hold them on with friction
I use the shopvac bags....this one doesn't have the slot, just the rubber seal and friction.
Lynden
Southern California
mikegt4
sw ohio
Some people use pool filter socks over their Shop Vac filter. Here is an example on YouTube.
Zeke
Are you using too small of a bag? A bag that doesn't reach the bottom of the inside of the canister will likely pull off the intake tube as debris accumulates in the bottom of the bag causing the bag to become heavy. For example, the bag linked below is sized to fit up to a 22-gallon vacuum and is about 19 inches in height.
Shop-Vac® 15-22 Gallon* Disposable Filter Bags (3 Pack)https://www.shopvac.com › products › type-g-9066300...
That's interesting. I thought SV went out of business.
CJ7VFR
Central New Jersey
The filter bags I have came with a pretty strong rubber band that goes around the top part of the bag
where it comes in contact with lower part of the suction fan shroud inside the vac.
Jim
mike93lx
Richmond, VA
Jim
That's a completely different style of "bag".
The bags that the OP is using capture the dust and keep the tub clean.
Jazz1
Thunder Bay On.
My wife had same issue but she was using a off brand bag.
CJ7VFR
Central New Jersey
Ok, gotcha. It sounded to me like he was talking about the little bags that fit over the filter in order to keep the filter from clogging up.
Jim
