ExactlyI use it all the time. The purpose of it is to keep spatter from building up inside the nozzle. It doesn't enhance your welds, other than to give better gas coverage.
I dip the nozzle quickly, when it's good and hot. I wipe off the outside of the nozzle and the end of the wire. After a while, you build up a coating of carbon on the inside of the nozzle and the end of the tip. That's what keeps the spatter from sticking.
If you're trying to keep the nozzle wet all the time, you just end up making a mess. Too much gel dripping into the weld can cause porosity.
Dialing in the machine is the best way to minimize spatter. Nozzle gel is just a help to keep the nozzle clean. Use of nozzle gel is misunderstood by lots of welders. Like wire lube, a little goes a long way.
Why wouldn't you use it, its cheap and it saves cleaning time. I use it on plasma drag shields as well. Also the spray stuff makes a good protective coating if you are around paint or chrome.
Because it costs money and takes all of 20 seconds to clean
Extending consumable life alone will pay for it. Also the 20 seconds or so adds up when welding with co2 or on crappy material where cleaning is required pretty often. You will see very few professional welders who don't use it.
Nice try no cigars, have a welder has the same slip nozzle that came with the machine, 7 years ago, did change the contact tip once. Welpers have been the only tool used. Nozzle snot is like octane boost, works only in ones mind.
" You will see very few professional welders who don't use it" post that one over at the WW, should go over like a lead ballon
Rock on
Greg
I read the whole tread waiting for someone to mention Pam. That's what I use, cheap and works great.Pam cooking spray works just as well.
Easiest way is to have a helper make fine adjustments on your wire speed while you are welding. Hold the arc lenght and gun angle like you would normally use, assuming it's correct, then fine tune to get the smoothest SOUNDING arc you can get. Once you get experienced to the sound and feel of the proper arc, it will come easy to make adjustments. If your machine has a parameter, cheat sheet, start thereI seem to always have this problem. Millermatic 175, solid wire, 75/25. I always seem to have spatter build up in the nozzle and tip. You guys mention to "tune" the machine to help, but no one mentioned how?
