Should I buy this Torque Multiplier? $105
Mohawk Dave
SoCal
It's a HF unit...doesn't look like it's made anymore. Dude wants $105
Saw a couple threads on other forums from 2009ish saying they used it and that was about it....no real reviews.
I read it is 3:1 ratio. 3/4" in-650ft lbs max, 1" out 2,000 ft lbs max. (I have 3/4" and 1" socket sets)
I have the Snap On 3/4 Torque Wrench, so I really don't need this for adding a 1/2" torque wrench to, but I'd like to have one for "one day might need it" for busting stuff loose etc.
Are these absolutely terrible, or are they a PASS from HF?
7thDimension
You'd have to hold onto that handle pretty damn hard to actually be able to apply 2000ft-ibs to something...
The tool is going to twist backwards with an equal amount of force to what you're applying to the fastener.
RedneckWelder
The Ghetto Kingdom of Methlandia
Not a handle, it's a reaction bar. You have to brace it against something solid (like the floor)
bbs lm-r
I don't think your pic is big enough :)
To OP, would you really trust HF **** with something as critical as a tq spec?
CNGsaves
KS and OK
It's a torque MULTIPLIER . . . it's purpose IS to create extra torque to break loose stubborn fasteners like axle nut shown in picture.
Wish a friend of mine had one when brother was struggling with Dodge diesel front "bearing assembly" that was rusted on. Instead, a torch and cheater bar were used, but with much struggle
Pretty sure variation of multiplier is what's used by that demo of woman easily loosening lugs on 18 wheel tractor, in prior GJ thread.
OP if you've got project or two that will use the multiplier, then go for it as $100 spent will likely yield you time & hassle savings.
/ my .02
M
Mohawk Dave
SoCal
Thanks guys. Yea, I don't need it for torque. I have the 3/4" Snappy for that.
But, if I watch the ebay, I can grab a USA made one, without ratchet (which I have several) for about $150ish.
And a little more I could just pick up a used IR 3/4 rattle gun.
bob15
Northeasten, CT
It's a torque MULTIPLIER . . . it's purpose IS to create extra torque to break loose stubborn fasteners like axle nut shown in picture./ my .02
Incorrect in your purpose. They are use for torquing parts together that have very large torque values. Not for breaking free stuff.
Read this and understand how they work:
http://www1.snapon.com/V2/Groups/cmsINDUKau/PDF/PDFUK/Torque_multipliers.pdf
Mohawk, I really not sure if you will ever need it. I have a 0-600 ft/lb torque wrench and haven't needed anything else. Are TM's handy? Can be, but I think I would save my money on that HF multiplier and spend it elsewhere.
