Should I consider a sub-panel?
duneslider
Riverton, Utah
I am wondering what the experts thoughts are on my situation.
I currently have a 40amp 220v outlet in the garage. I don't currently use it but I plan to get a welder, nothing huge, just typical hobby homeowner occasional use kind of stuff, and I may use it occasionally to plug in my camp trailer for testing the A/C. I don't anticipate this current 220v to get used very often.
Since the world is moving to electric cars I have wondered if it makes sense to run a 60amp outlet to the garage before I finish the basement and lose easy access, just in case I someday want a higher amp charge station. If I am running more wires would it make more sense to just put in a small sub-panel. Or is running the 60amp to a "plug" a better/fine idea? Or should I just run the wire and leave it "unconnected" on both ends and I can decide later what to do with it?
I don't anticipate needing power for anything else in the area. Garage already has plenty of circuits and outlets, so I don't anticipate needing more 120v outlets. Am I crazy to even be thinking of a subpanel?
I have oodles of room in my main panel, so I don't have a need to add more room for breakers.
mike93lx
Richmond, VA
The plug for a welder is different for a RV and is different than a charger.
I would do a sub.
mark-NJ
new jersey
I'd give anything for a small sub-panel in my garage. My vote: you bet!
For me, it's not about "current", per se. It's more about convenience of outlets & branch circuits: when I'm welding, I'm not using my table saw. When I'm using my table saw, I'm not running my jointer...etc. (All are 240V)
D
duneslider
Riverton, Utah
Thanks for the input so far, I was leaning towards a small subpanel, only real disadvantage to that in my mind is that it would take up more space than the other options but that isn't a deal breaker.
D
duneslider
Riverton, Utah
is there a neutral with your 40 amp circuit? if yes I (think) it will be fine for an EV charger and probably sufficient for any thing else in the garage .
Yes there is a neutral on the 40amp circuit. It is currently wired to a standard 14-50R just like what is in the kitchen for the range.
D
duneslider
Riverton, Utah
If you're going to upgrade, why not go 90/100 amps right away?
I can't imagine ever needing 90-100 amps in the attached garage. I question if I will ever even need 220v in the garage, if I do it would be a welder or a car charger. Not sure I could ever justify a 220v welder either, I just don't do anything heavy enough to need that.
mike93lx
Richmond, VA
You could just put a small sub on the wire you already have. It will at least give to an easy way to add whatever plugs you want and have them breakered properly.
A 6 space sub is pretty small and inexpensive. Just need to isolate the neutral bar and get a ground bar kit if it doesn't come with one
dcg9381
Austin, TX
Not necessarily true. I use 14-50P for both. 14-50R @ 30A breakers. Makes stuff easier.
OP, most modern EV chargers you can "set the rate" - 40A may be more than enough for an overnight charge, depends on what you're doing.
mike93lx
Richmond, VA
You can put any plug on anything if you want. That doesn't mean that it's standard. A welder using a 14-50 is definitely non-standard and a 30a breaker will not work for some welders.
14-50p is not standard for a welder (a 240v welder doesnt need a neutral) and many smaller RVs use TT-30 so...
D
duneslider
Riverton, Utah
So, my trailer does have a TT-30 but I have one of those adapters that came with it that converts from the 14-50 to the 30.
I have also seen adapters that convert from the 14-50 to a 6-50 for welders. I can see how dedicated outlets would be ideal for all these items but is there anything wrong with using the adapters for occasional use?
mike93lx
Richmond, VA
Guess it depends on the quality of the adapters.
ddurrett896
VA
Never say never.
I built an attached garage and my homes main panel is in a weird spot that makes fishing wires hard. Ended up cutting into the wall and running 100amps to a sub in the new garage with all new circuits off that subpanel.
2 years later....that subpanel is feeding another exterior subpanel for my pool equipment and the exterior subpanel is feeding a detached garage subpanel I'm currently building.
D
duneslider
Riverton, Utah
That's been my thinking. I may just run the wires and not connect them on both ends and just have it there just in case.
Noltz
Ontario, Canada
Pull for 100A now. Cars will be the biggest draw in the future. Buddy had his house built ~5 years ago with the 200A service entering the Garage panel first for his two electric cars plus the hot tub and AC. The house is set up as a sub panel.
Digital Spaceport
I just got done rewiring to upgrade my garage subpanel from a 50amp to a 125amp. I'm glad I had that 125amp panel in the first place, but should have installed a bigger service to it from the get go. Wire is expensive but redoing wiring is even more expensive. Also welding is fun and addictive. You might really like it. I know I do now.
Syberia
Perris, CA
I didn't either. But I've seen 70 amps or so charging two cars, mini split running, and using a table saw or something.
Daniel Dudley
I upped my garage to a 100 watt sub panel some years ago. It seemed like a lot then, but just adequate now.
Daniel Dudley
Thanks, I was just talking about light bulbs a few minutes ago. Watt a difference. I never thought I would need more than 50 amps in my garage, or more than an 8 foot ceiling. I could go back and run another line to correct the power, but it cost me, because I couldn't imagine needing more 22 years ago. Save a nickle, spend a dime.
