I needed a jack at work to lift a 700 lb piece of equipment. I went to harbor freight and purchased a 1.5 ton Daytona Jack with a flat runner coated lift pad. Looked nice. Plenty of margin for safety.
Also purchased 2 jack stands.
Lifted the equipment installed jack stands and cribbing. Removed jack, Got the motor and gear box pulled.
Went to put the jack back and lower equipment and the handle was jammed. Took a look and the jack pins that push the hydraulic fluid are anchored by 2 washers and a spring. The washer popped through the spring.
Do not trust a jack to hold anything while you work. Please. And this is going back tomorrow and no I’m not buying another.
Any suggestions on where to buy a jack of decent quality. For non automotive work. Mostly under 1000 lb equipment.
