Should I get a plasma cutter/will I use it
Burt Shaver
Iroquois, Ontario Canada
I seen a CUT50 plasma cutter for sale on marketplace for 150.00 CDN, It’s dual 110/220 volt. I would only have a 110 /15amp circuit to run it on so I guess the most I could cut with it is 1/4” ?
I don’t really have a use in my mind presently but it’s super cool. I currently do all my own repairs on our vehicles, kids vehicles, my ATV’s, snowmobiles and seadoo’s as well as all our own home maintenance and repairs. I will need to make some repairs to my dump trailer one of these years soon and I have an interest in doing some body work but have never done any. I have a Lincoln Mig Pak 40 welder that I use very occasionally but it is handy to have when I need it, I bought that used as well for a good price so I’m happy to have it. I was thinking for 150.00 the plasma cutter would be the same?
Do I need some type of gas for a plasma cutter?
Crazyjake8493
Upstate NY
You need compressed air to run a plasma cutter, typically using a regular shop air compressor.
I've been wanting to get one, and I would definitely find uses for it once I have it. I've just been waiting until I really need it before I buy one so I don't let part of the warranty period go by while it sits in the box in the garage for too long.
I really could've used one in the past instead of burning through cutoff discs and jigsaw blades.
Burt Shaver
AI says 90 to 100 psi at 4.5cfm . I will need to go check my tiny shop compressor, it’s pretty small so I doubt it will do it, I’m positive the compressor I use for duct cleaning would though
OccupantRJ
Eastern North Carolina
I have a Thermal Arc Pak3xr that I bought cheap from friend and member Beyond1. Works fine. So far I have used it twice in ten years. I tend to do more repair and refurb work these days than fab work as I once did years ago.
whateg01
doo dah, kansas, usa
A plasma cutter certainly could do that job. You may find that once you start cutting into it, by the time you get to good metal you've cut away 90% of the trailer. Btw, they do make or at least used to make plasma cutters with built-in compressors. As a plasma cutter, I don't think they were ever that great, but the convenience of not having a separate compressor I suppose does have some value. Of course a lot of those are older and not supported and probably hard to find parts for nowadays. I also think that you would struggle to run one of those off of a 15 amp 120 volt circuit even if they made them in 120 volt models.
Renegade1LI
long island ny
I've found they are great for demo work, also where having stored tanks is a problem. We can demo large boilers in place without oxy/act tanks which can't be stored in the building. Plus I uses the buildings power so that saves some$$$. In the field or the shop i use them alot, just size it accordingly.
Bert_
NW Iowa
I got a 50A prime weld last December. I love it. It's hard to justify because you can do most of the same stuff with a cutoff wheel. But I don't use a cutoff wheel very much now.
I've cut 5/8 with mine. It wasn't super happy about it but it did it. 1/2" is no problem.
djbmw
Ottawa, Ontario, Canada
Darn, I went back to it to message and it was sold
Im surprised it sold for that much!
They are $160 brand new from Amazon without a pilot arc... and $210 with a pilot arc.
If you use a cut off wheel often enough right now, your plasma will replace 80% of that work and will get the job done in a fraction of the time. Consumable cost is similar to a cut off wheel as well.
Longevity of a chinesium cut50 from amazon tends to be in the ~15 to 20 year range (or 250 hr-ish range) before components start becoming crispy.
Burt Shaver
In my mind I pictured the plasma cutter being able to cut inside bends where there are pillars and such easier than a cut off wheel, I also find the cut off wheels dangerous because they can explode. It’s never happened to me but it happened to a fellow I once worked with.
That’s 220v correct?
Burt Shaver
Bert_
NW Iowa
It does everything easier and faster than a cutoff wheel. But it doesn't do a lot that you can't do with a cutoff wheel.
Mine is dual voltage just like what you are looking at.
120v is nice to be able to use it out somewhere on a regular extension cord. But if you are doing much cutting you will get tired of tripping the breaker.
If you're using it in the shop just wire a 240v plug
zendriver
Indiana
Suggest not even getting hung up on one "brand". If they lunch most are throw away items, anyway.
have a 50A "Bestarc" that's about $30 less than I paid for one two years ago. I've used it a total of three times. Works great. If I were to wear it out i'd get another. If it unexpectedly quit, I'd get something else.
There are worse things to spend a couple of hundred on.
PhantomEB
Medicine Hat, AB, Canuckistan
I have the HeroCut Cut35i, my little compressor ain’t up to snuff but I can tell you when I upgrade the power to my garage over here in Medicine Hat Alberta, I plan to get another compressor like I had plus 20 amps down both sides of the shop. I very well could see myself getting the ArcCaptain 55 or even 65 plasma cutter. This ArcCaptain multiprocess was a game changer for me over my old Miller 175 MiG.
Bert_
NW Iowa
I'm surprised at all the talk about not having enough air. I see some millwright guys running them with a pancake compressor. My 1.5hp has never struggled.
Maybe if it was on a CNC table doing constant cutting. Normal people will never have an issue
willf650
Would a plasma cutter be the appropriate tool to cut out rusty pieces on my dump trailer? I can take some pics tomorrow
I’m not a welder by any means but bought a cheap one similar to what you posted and used it for more or less that exact purpose.
I cut out frame sections on my jeep and welded in replacement sections on it. Have used my welder 3-4 more times since and the plasma cutter has sat on a shelf.
Burt Shaver
You have it if you need it though
