The Money Pit
Today it was 92* outside and I'm insulating the room above the garage. Just out of couriosity I took a digital thermometer to the second floor to see how hot it was up there. It will give me two readings because there is a sensor attached. One is for the inside temp and the other is for where ever you put the sensor. I stuck the sensor at ceiling height and left the other at eye level. It read 110* at eye level and 123* at the ceiling. I didn't go out until it cooled down to about 85*. I was wondering if I should have a ridge vent to keep the heat down. I will have HVAC for up and downstairs, eveything is going to be well insulated and nothing will be stored in the small space above the ceiling. I do have the "egg carton" styrofoam in between the insulation and the sheathing for air flow, but will that be enough?
