alex3610
I have a 24x24 attached garage with a bonus room above it. The ceiling of the garage is insulated (unknown other than yellow fiberglass circa 1986) and has sheetrock. The other exterior walls are not insulated, and I guess the house was sheathed with what looks like a masonite product. Exterior wise the front and side of the garage have brick veneer and the back side of the house is vinyl sided. There are 2 wood garage doors with single pane glass in the top panel of the doors. There is a newer man door on the side of the garage. There are two double pane vinyl windows that are on the front of the garage. (rear entry garage).
The issue is the bonus room above. It's cold in the winter and hot in the summer. The duct work is fed from an electric furnace in the attic at the opposite end of the house. It's typically several degrees behind the rest of the 2nd floor of the house. My assumption is much of this comes from the unconditioned cold/hot air in the garage below.
So is it worth the expense to insulate and close in the 3 walls of the garage? I realize the wood garage doors will need to be addressed as well or we will never accomplish the goal. One of the bottom panels is starting to rot anyway. My one other concern is that once insulated, during the summer when we bring the cars in we will trap the heat given off by the cars. Thoughts?
