Should I just buy new drip edge?
TravelingLight
Southeast U.S.
My lumber delivery was eons ago. Just now unwrapping the drip edge. A lot of it is pretty bent up on the drip side (non nailing side). See pics for reference. Is it worth it trying to straighten these out by hand or easier to just buy new ones? 12x20 shed, would only be about $45-50 for new drip edge. Thoughts?
tncatadjuster
Memphis, TN
Nothing a couple of 2x4 blocks and a hammer can't fix. Maybe not perfect, are you going to look at it each time you pass by? If so, buy new. Jigsaw out a die and hammer away.
T
TravelingLight
Southeast U.S.
Good call. Didn’t even consider blocking and a hammer. And you’re right, I can put the crappy ones on the sides that aren’t visible for the most part. Thanks.
Stuart in MN
Minneapolis
If they were damaged when delivered, even though it's been a long time it may still be worth a call to the supplier to see if they'll replace them. Worst case is they'll refuse, but all you're out is a few minutes on the phone.
The Cobbler
looks like they've been laying around in the dirt.
depends on how bad they are bent i guess. if you can straighten them to look OK, use them, otherwise replace them. it might be hard to get them buckle free tho.
NUTTSGT
Northern Central Ohio
My thoughts are the same as Stuart. This would be my first attempt.
SGKent
Citrus Heights CA
straighten an average one, lay it up there, and see if you can live with it, and if there is any technical reason it won't work.
Dumber than lumber
This is GarageJournal.
Which means you are spending your own money and you get to choose.
We are just here to give advice and support and encouragement;
to be enablers and to be enabled.
p.s. straighten that **** out and save the money for tools
1MtnGoat
Cleveland, TN
Straighten and if you are going to have any gutters put the bent ones where there will be gutters. You'll never see them.
