hofferwood
Or just get bigger fuses???
They were out of fuses
Does that panel have a ground wire to it? Or is that emt continuous all the way back to the main panel?
Fuse panels around that era were notorious for only having 3 wire feeds to them (which isn't what you want) and no ground wire. They usually had the neutrals and grounds landed on the same neutral bar to make up for a lack of ground wire.
Shouldn't the feeder wire be four wire with two hots a neutral and a ground?
I'm not sure about that old white 12ga romex though... LOLjk
