Should I upgrade my wire stripper tool ?
Jacobson
I use the tool a few times a year
It's something I've had since the 1980s
It never seems to work well, but that very well could be operator error.
Are modern designs easier to use?
Which would you suggest? Budget/value for home DIY
BrandonV
Arizona
I'm not a fan of those combination tools. They tend to do none of the functions well.
Any decent American or Taiwanese wire stripper (Klein, Milwaukee, Ideal, Southwire, etc.) will be night and day better. Even the "better" HF brands are decent (Quinn/Icon).
Hit me up via PM I might have something you can have :).
Caby
I have the Irwin as posted above... Love It!!! (although it's made for right-handers, and I'm a lefty...) It's too difficult to get the wire in the right guage mark on the traditional stripers... I often nicked the wires...
Shiftless
East Bay SFO
I still use mine but only for the screw cutting feature. That part works great! For sripping wires I use one of the better models.
LopezBart
Lopez Island, WA
I've used both the Irwin and the Klein. For me, it depends on the amount of space I have; the little Klein is definitely easier for me in tight quarters repairing trailers, etc, and it takes up less space in my electrical bag. The Irwin is faster when doing a lot of stripping but less forgiving of dirt, etc.
Caby
YES! the screw cutters!! It's amazing, the number of people who have no idea the feature is even there!!
Butters
I typically use Klein wire strippers (one for smaller gauges and one larger) and the ratcheting style crimpers.
(I also frequently ignore the stamped warning at the bottom :devilish:)
Meursault74
Southern California
Yes
I still have one like that, but I don't use it anymore for crimping or stripping as it's not very good at it. I still use it to cut screws though.
I have a couple of strippers and a dedicated crimper tool
I also have this one from HF as it can get into tighter locations. It looks like it's on closeout now. 3 bucks, wow.
They also have another like this in Pittsburg brand.
Pretty much any other stripper will be better than the one you have,
manwithtools
Lebanon, TN
bcradio
New Mexico
CoogarXR
It's not you; those kind of strippers/crimpers just don't work very well, period.
Any of the suggestions above would blow those away.
BrandonV
Arizona
What's the difference between the two types Butter posted ?
V-notch strippers have their place.
If you strip thousands of wires a day you'll get excellent results because it's highly dependent on skill and the user's feel. I've seen folks strip wire cleaner on those than any pair of Kleins. Not all wire has the same size insulation.
The second pair is okay but I'd get the Doyle version which I use all the time. It's solid.
manwithtools
Lebanon, TN
@BrandonV In our business we have 20 full time technicians building electrcial control panels all day long. All they do is route wires, label them, strip them and terminate them. Thousands of connections a day across those folks. None of them have ever used v notch strippers nor would they recommend them to anyone. No one who strips a lot of wire likes them.
BrandonV
Arizona
Opinions. Everyone has one. My father started out with a guy who refused to use a meter on electrical panels. His hand was more than sufficient to determine if circuits were live.
A lot of people use the cheapest V strippers infrequently enough to get a bad opinion of them. Very, very, very fine solid core wire (telephone and smaller) they work wonders on. My experience is with 24 gauge and smaller.
Pexto
Yep, I too used to think those v-notch strippers were junk. Then a couple of friends who run a lot of comm wires told me they use those all day, every day. I seriously thought they were just messing with me, but no, it's their tool of choice for the very small wires they use a lot of. Apparently there's nothing faster and cleaner once you get used to them.
But for ham-fisted me, mostly dealing with larger wires, like 18 ga and up? I still don't use mine!
Madjik Man
I too used one exactly like this for 30 years. Just embraced the ****.
Then I bought one of these Klein self adjusting ones years ago before installing a fuse/relay box with switchbacks in the truck cab.
Have never touched the old school ones since.
BrandonV
Arizona
All depends on what you're working on really...
For one project we were using automatic strippers and then they found one nicked wire. That nicked wire became a million dollar issue.
We bought laser strippers after that.
Buckaroo5
Central Ohio
I got a Klein 11063w as I was doing a kitchen remodel with a fair amount of electrical and figured I could justify a nice tool. It works well and makes stripping wires a pleasure. Like almost everytime I upgrade my tools, I wondered why I waited so long to get one,
Meursault74
Southern California
regarding the V-notch strippers. There's two kinds that I've used. Ones as pictured above where it has a settings for each common gauge wire, and one like this where it's infinitely adjustable like this Stanley.
MongoTA
CT
I have the same one, used it to wire my house. I still use it but these days occasionally, once every couple of months. If I was in production work I'd get something better, similar to the $22 Irwin that was mentioned. I did see a review where the only drawback to the Irwin was stripping romex conductors that have a plastic-type coating on the insulation, like NM. The Irwins will grab the plastic coating but might not grab the actual insulation on the conductor. Might take multiple strips to get it to grab and strip the coating before it can grab the insulation under the plastic coating.
The Klein Katapult has the same issue with NM conductors but it doesn't seem to be as bad. When looking at the two, it looks like the teeth on the Klein are more aggressive so they'll get a better bite.
richfinn
Leeds, Yorkshire, England
Good thing wire strippers aren't a subjective thing... As long as the insulation is removed and the conductor isn't compromised and the user is happy it doesn't matter.
They aren't, you are 100% correct, my opinion is basically meaningless in the grand scheme of things despite me trying out almost every wire stripper on Earth as a jobbing auto electrician and coming to the conclusion "you know this cheap $25 German one is the best quality I've ever used and never ever fails performance wise, I'll spread the word on GJ and hopefully save my "tool buddies" some cash and frustration" 😉
BrandonV
Arizona
I agree. All I was getting at was it depends on your use case. Insulation quality, thickness, etc. in the automotive space is different than the telecom space which is different than the home electrical or commercial electrical space.
I guarantee I have some wire those automatics would struggle with.
richfinn
I'm pretty sure you do, however for a general purpose wire stripper these are the absolute bomb/and almost disposable cheap. But please watch the video.
They perform better than both the expensive Knipex versions (and all the rebrands) and are made in a first world economy, which will tick a lot of boxes for GJ guys
I would never recommend junk to my fellow tool enthusiasts, I've been in the game myself for nearly 40 years 👍
BrandonV
Arizona
Fair point. I will check them out.
Sorry I have to shut off the engineering switch sometimes.
Are the Knipex rebrands or a clone of them?
richfinn
I honestly don't know if Jokari/Knipex/Paladin are all exactly the same tools or not to be honest, all I can say is Weicon are now a GJ trusted brand in my opinion, a bit cheap/ugly looking but they do work really good on relatively small wires in my experience.
I had never even heard of this brand until another British Auto Electrician scoffed at my fancy collection of strippers and said "WTF are you wasting money on that sh*t for" (In a humourous Northern English accent)
So I gave them a go as they were cheap, I was suitably educated (by a cantankerous old tw@t) 😄
