Should I use this American Scale vise?
Joe B.
I don't think I would bother with that one even if it were free. It was light duty to begin with and who knows about the repair. It also does not look like the jaws line up anymore so it my grip in an odd way.
If it were mine, I would toss the welded part and give the rest of the parts away in the vise parts thread. Someone may need to base or the other good parts.
Lightfoot
If it works, why not use it till it breaks?
If it does break again, it's likely to be in the part that has been previously repaired, then part it out. I mean, i wouldn't buy it like that, but if you already have it, use it.
gatewaysysop
Arizona
Use it until it breaks, thus justifying the purchase of another, larger, beefier vise at a later date. Clearly the only viable solution. :D
shingo
Illinois
Is my American Scale #600 considered light duty? It has 6" wide jaws. I just found out that I live around 600 feet from where the old Wilton Vise company was located. The building burnt down around 35 years ago.
Thanks for all you answers, I really like this forum.
In this case, the width of the jaws is not an indicator of how heavy duty it is. The exposed screw, and the two part dynamic jaw makes it light duty. Where it was welded (Braized? Is it brass or steel filler?) was originally where the bar was pressed into a socket in the lower part of the jaw. Someone cranked on it or pounded on it and broke the socket out.
I have a similar design Colombian and it was broken and braised the same way. The dynamic jaw was not heated up properly getting a cold joint, and the braze ripped out. I'm probably going to redo it and doc it to show how to get it done so it has a prayer of holding up at all.
