stanleyoutdoors
I'm putting a new Pro-X (japanese) piston and rings into my KTM (Austrian) 525 dirtbike.
Bore is freshly honed.
Piston and bore diameters in spec (on loose side)
Both compression ring and oils scraper ring end gaps are within spec (on loose side)
The oil scraper rings are the type where there is a wavy spring in the middle, flanked by 2 thin rings. The inner diameter of the wavy spring has a crimped ridge that makes the rings touch the ridge rather than the OD of the piston groove (effectively forcing the oil rings outward)
I am very sure I am installing it correctly, but it seems that the wavy spring is pushing the rings out too much. With the (much larger) compression ring, I can easily squeeze it with my fingers to get the gap to close and shove it in the bore. With just the compression ring, it slides nicely. But with the (much smaller) oil rings, I can not squeeze them hard enough to close the end gap, due to the wavy spring pushing them outward. Using a ring compressor tool, I managed to get the piston in the bore, but it was really difficult to make it slide up or down. (I had oiled it up really well)
Is it normal to be that tight? Most of my other experience is with 2 strokes (no oil rings, only compression ring(s)). And the last time I rebuilt this engine, I kept the stock piston and used new rings, but the stock oil ring is 1 piece plus a coil spring. I don't remember it being nearly this tight.
THANKS!
THANKS!
