Show me a switch.
MUDFORD
I'm looking for a switch for a gary slitter. 120v single pole. On-off-momentary on. Ordered a few different things but no luck. Local supply house doesn't have anything.
edited to add:
normal old school looking switch in a single gang metal box.
MUDFORD
The factory switch is a simple off and on wall switch. I wanted something with momentary to make it easier to line up the set screws for blade adjustment. Not totally needed.
sparky 1971
Central Iowa
I've never seen one as described that has definite on/off positions along with momentary. That doesn't mean there isn't such a thing though. If there is room for a two gang box, or even another single gang, how about a single pole, double throw, off position in the center, along with a momentary toggle switch? One throw could be the normal on/off and the other throw could go through the momentary.
Edit: I didn't post my entire thought process. Having a DPDT switch would prevent accidental bumping of the motor. I will admit to not having a clue what the machine does though. Maybe reaching down and flipping the wrong switch wouldn't cause any problems if it were to get paralleled in along with a SP switch.
gotham
Colorado
(on) refers to momentary. These are (on) - off - on
