Show me how you store 1/4" hex bits, please
Jononon
Mine are in lots of Wiha folding holders, which are somewhat fiddly, don't make finding the right bit easy, and take up a ridiculous amount of space.
There must be a better way?
beelsr
NE PA, USA
grab a piece of wood and start drilling some holes.
or use the plastic holders like @mrholeshot.
DynoDale
Pittsburgh, PA
I use Mechanics Time Savers magnetic holders:
[URL="http://www.amazon.com/Mechanics-Time-Savers-MTS584-Magnetic/dp/B002XMOQTY/ref=sr_1_30?ie=UTF8&s=hi&qid=1279558119&sr=8-30"]http://www.amazon.com/Mechanics-Time-Savers-MTS584-Magnetic/dp/B002XMOQTY/ref=sr_1_30?ie=UTF8&s=hi&qid=1279558119&sr=8-30[/URL]
J
Jononon
Thanks :thumbup:
Sorry, can't help much. I love the Wiha holders just fine.
The old Bits-Selector was great, it's the new folding X(L) Selector that I find irritating. Unfortunately I have two of the former and four of the latter.
JBERTSCHY
I use the small black boxes that the mini mag-lites come in. I have them for standard and metric and if you count that I usually pitch them in the trash then they are free...
JOSH
EZH
Dallas,TX
http://i703.photobucket.com/albums/ww32/dynodale/Screwdrivers[/QUOTE]
I've always wondered what the fat hole in the center is for on those MTS holders. Some kind of adapter or something?
Eric
senlow
Wheat Ridge, Colorado
Those mechanics time savers look pretty cool! but at over $20 shipped, thats a bit pricey...
It's easy to make a similar bit holder yourself.
You will need some thick plastic sheet. For this type of project I prefer either UHMW (think plastic kitchen cutting boards) or solid surface countertop material like Corian. It is often possible to obtain Corian remnants inexpensively from countertop fab shops. Both can be easily machined with typical woodworking tools such as table saw, router and drill. Just cut to the size and drill holes most of the way thru the material. Don't forget to chamfer the bores.
For a magnetic bit holder, just drill the holes thru the material, and adhere a magnetic strip to the bottom of the holder. Magnetic strip is available from The Magnet Source and other vendors. If using UHMW for the holder, be sure to buy magnetic strip with an adhesive thats made for that type of plastic. UHMW is slippery, and few adhesives work on it.
A guy could make 'em out of wood too.
Stick Figure
Omaha, Ne
I'm lucky enough to have access to a mill and scrap aluminum ;)
i.php
i.php
i would like to redo them and put them all in on piece, but i've got some projects to do on some tap and die sets first.
Dust
Santa Ana, CA
Magnets from K&J Magnetic. I typically use 2"x1/4"x1/16" magnet blocks. Note that that picture is old, and I have many more bits available now, with more magnets. Those are also my most used bits as well. All my other are in a big plastic bag, since I usually don't have to use them.
mikemolzahn
Ozark, Mo
Old semi-clear 35mm film canisters is what I used to use in my boxes. Now I use those flat tackle boxes with dividers. As for the 35 mm film canisters you can find them on e-bay in bulk pretty cheap as photographers getting rid of them.
Mike
J
Jononon
Some great ideas, thanks :beer:
I like the MTS set up, but - senlow Would it be feasible to bond chopping boards together to make deeper blocks? I can buy an awful lot of them from IKEA for the price of one MTS holder!
beelsr
NE PA, USA
I squared the piece of maple and then used my incra scale to make the lines. Once I was done drilling, I gave it a lick with the belt sander to remove the lines. Easy peasy....
If you are drilling your home brew bit block lay out some graph paper and drill small pilot holes first. Makes for a good looking set
