Show me some light gray wall paint..
BellyUpFish
Alabama
So, I’m all primed up and I’m trying to decide on final colors.
I was all set on a semi-gloss white until I started thinking about a light gray in semi-gloss.
Anyone here go solid gray on their walls?
428PI
Peabody, KS
A neutral gray will look just like white in a photo depending on the camera's exposure.
tom-ky
Morgantown, Ky
Did a light gray on mine, you can see the contrast compare to the compressor.
CKS1955
I did a light cape gray on my shop walls and really like it. I was going to leave my T1-11 natural wood, but it made the shop to dark.
Jay
mike93lx
Richmond, VA
There was another thread recently on this topic. Try using Google to search since the search here isn't that good.
Semi gloss will show every imperfection and will have a glare. I would only use even satin on a really smooth wall. Semi gloss should only be on trim, IMO
Dentaltec
Redlands Ca
I guess I am just set in my ways but any place I want to see clearly I want the brightest white paint money can buy, add more light than you need and make that space glow.
Color or lack of is over rated in my mind but to each their own
_Stang_
Bright white top, red stripe, grey bottom. Reflects light where you need it and hides scuffs dirt down low.
BellyUpFish
Alabama
My walls are far from really smooth. They’re OSB...
Brian80
Pennsylvania
I used a paint/ primer from Lowes the actual name is called Drizzling Mist. click the link in my signature for interior pics
xyster101
Upstate NY
I have OSB walls. I painted them all grey with 2 coats. Then went back and added the red strip just to mix it up. I also have painted all the things I make red like the workbench, wall racks, etc. Mine is more of a dark grey, but I did a ton of lights.
BigBri
Louisiana
Light gray with white ceiling and dark gray trim
Vassar, MI
I'm going with gray walls and flat white ceiling in my shop as well. I just finished painting my cold storage room. It was somewhat of a battle to get the right tone of gray.
My local hardware store had a sale on paint a couple months ago, buy one get one free.. so I bought 10 gallons. The color I chose was called "gray flannel". At the store it looked great. I started painting and did all of the edging-in and by the time I was nearly done, some of it had almost fully dried and turned out to be really blue (see attached pic). Not what I was hoping for.
I took all of the paint back and had it tinted to get a different shade of gray. I learned a lesson from the first attempt, so I just quickly painted a 4'x8' area and let it dry fully before I went any further. The next day I checked it out and it was purple-ish. That wasn't what I was hoping for either.
Third attempt at tinting the paint seemed to work out. Though it's a little darker than I hoped.
I see you had said you have OSB on your walls, as do I. My advice would be to use a good primer to start with. I used Zinsser Bull's-eye 123 primer. It's very thick and covered in one coat. The paint also covered in one coat.
I would also advise to choose your color at the store, but try a small area in your shop and let it dry fully before going to town and wasting a bunch of time only to find out it's not the right shade. Chances are the lighting in the store and the lighting in your shop will vary. b0b9fc1bdc89ac3aeefde25f70fbcb8a.jpg
Sent from my Pixel 3 XL using Tapatalk
bctexas
Aubrey, TX
Light grey floor and walls. Paint is two coats of exterior satin on osb.
bdbecker
Iowa
Different strokes for different folks... you're ideal setup would drive me bonkers. My Dad's shop is setup this way (bright white tin walls and ceiling, tons of fluorescent lights) and I can't stand it. Just being in there makes me anxious - like I'm sitting at some interrogation table from an old cop movie (the cliche scene where they put the lamp on the suspect to make him crack). Plus, if I'm not wearing tinted glasses, its a guarantee I'll have a headache within a half hour. I do like bright lights over task areas, but otherwise give me warm colors and 60 watt bulbs.
Northislander
Vancouver Island
I have light grey walls in my shop with lots of light and love it. Unfortunately i used Douglas Fir trim with tung oil finish and in a pic. you can't tell the walls arn't white. Attached pic. is my wife's art studio which is under my shop (suspended slab) same light grey walls but white trim so you can see the difference.
countrysquire
League City, TX
I went with the Benjamin Moore Grey Owl. It’s light and has a high reflective value, but as you can (hopefully) tell in the photos, has a nice contrast from white.
hans109h
Upper Midwest
I used Gldden total exterior paint in a light grey called Tornado on the interior walls of my garage and I'm very happy with it. I mainly uses exterior because I was painting when it was cold out, but I'm glad I did as it's a tougher coating and allows me to easily clean it up.
rangda
Sherwin-Williams SW 7651, Front Porch. The window trims are gloss white which will give you some comparison as to the level of grey.
Git
S Cal
I thought all white walls and ceilings was just a little too bland so I painted the walls, cabinets and trim in 'pewter'. After a couple of years I ended up installing cleat wall strips but there is a 1 1/2" gap between each strip and you can still see the grey. I still like it and would do it again in pewter
tcianci
Walpole, Ma
No pics here but I did my skip trowel plaster walls in a semi-gloss medium grey.The skip trowel finish scatters the light so the semi gloss doesn't appear to glare but the finish vacuums up perfectly clean even after nearly 20 years. I have a grey epoxy floor and the trim is teal. it makes a nice contrast. Ceiling is white.
