gahrajmahal
So last summer I finally purchased a real soldering iron. I bought a Weller WESD51.
I just put in a clear plastic bin and whenever I wanted to use it I noticed it was a pain to get it out, find a place to set it up, and solder my few items only to put it away again. Additional tools, strippers, crimpers, solder and paste are in other locations, so I was gathering then replacing. Not my style of specialized tool usage. Typically I keep a specialized tool in its plastic tool box then add all the tools, wrenches, cutting blades, sandpaper etc all together, even going as far as having a small drill index and tips assortment with my variable speed drills. What I am hoping from you all is to see some different versions of your soldering setups, work holding plus tools and all consumables you typically use. If your setup is portable, all the better. A Google search has offered this one example, but I know you all can do much better. Thanks in advance for your contribution (and photos!)
