PCO6
I haven't seen a thread on this so I thought I'd start one.
First up, because I just want to get it out of the way, is my cheapo portable band saw from Princess Auto. This is probably the worst sounding tool I own. It growls and whines every time I use it. It sounds as if the blade is way too tight but I know it's not. Despite giving me no confidence that it's going last through an entire cut it works great! ... for now any way.
View media item 35110
Next is a 4"x6" band saw I bought in the mid 80's. A lot of people complain about these saws but mine has worked flawlessly. It seemed to go out of whack after about 10 years but when I figured out how to adjust it I enjoyed using it again.
I bought a second 4"x6" band saw a few years ago. It has a "swivel head" ... more to follow. I decided to sell my original 4"x6" but realized I'd be lucky to get $50 for it given it's age. I decided instead to convert it in to a dedicated vertical band saw. It has its limits compared to larger, better, etc. metal band saws but it meets my needs.
I had a stand I made years ago and decided to use it as the base.
View media item 35105
I cut most of the original cast iron "vice" section of the saw off and bolted it to the base.
View media item 35106
I capped off the altered base with a piece of 1/8" steel plate that I cut to fit.
View media item 35109
I dismantled most of the saw then cleaned, painted and reassembled it.
View media item 35107
Here's the finished product. I made a table out 1/8' steel plate and mdf and put an old milk crate underneath for band saw related clamps, jigs, etc.
View media item 35108
Finally, here is the 4"x6" swivel head band saw I mentioned. It currently sits on a stand I have mocked up. The stand for these saws is MUCH better than the flimsy 4"x6" saws but I wanted something that provided some storage. I bought a simple intermediate tool box and it will work well for that purpose.
View media item 35102
These 2 shots show the benefits of a swivel head saw. Unlike the standard 4"x6" band saw, when you want to cut on an angle you don't have to reposition the material being cut. This makes things a LOT easier in tight quarters.
View media item 35103
View media item 35104
Finally, you need a good material support for the piece being cut. I made this from an old single jack stand I had. I have no idea where the other stand got to.
View media item 35114
Let's see what you have.
