Show us your cool, "old" drill press
Faria
Hi!
I would like to know it's age (well ,more or less) and specialy the original colour.
After scraping the several layers of paing that cover it ,seems the bottom one is a sky blue...but i
just can't be sure...
Fretters
South Yorkshire, England
If you do a search on the English forums, you should find plenty of examples of colour. I seem to recall seeing them in several colours, especially green, blue and grey, though as to which of those were factory, I honestly couldn't say. Sounds like the one you have will be something like the colour of this one currently on Ebay?
http://www.ebay.co.uk/itm/111318555767
Faria
Yes , the colour looks like that one , mine only seems to be a litle brighter ...
Tomorow I'm going to remove those litle tins with the gearing indications and (hopefully) the original paint will be intact under them!
And what about the age of this machine? Any clue?
Ahicksv
Atlanta, GA
Before, picked up from ebay, looks and felt like it sat outside for years.
After
Sandblasted cast iron pieces, lots of sanding on all the steel, added a toggle switch to side, and now just waiting on new belt.
Ahicksv
Atlanta, GA
Appreciate the compliments. I am happy with the results.
The vise clamp is pretty handy, came with another floor press I picked up awhile back. I think it works well.
-Brent-
Utah
Vise-Grip 11HD 11-Inch Locking Hold Down Clamp
AWESOME! I found a tool I need/want/have to have. Sadly, that exact clamp is discontinued.
There are others, I think. That's for a different thread, though.
Kaervak
Cleveland, OH
Picked this up last night after work from craigslist for $50
Craftsman 103.23640 It's only missing a couple small pieces that I should be able to track down, but the important part is no arc of shame at all and no cracks in either base. Everything works perfectly on it too. It is a drawback that the motor isn't period correct or has the right pulley (or wired even remotely safely!), but that can be taken care of. Very happy with the purchase.
Kaervak
Cleveland, OH
Nice find; Model 80 I think? 2-1/4" post?
Near as I can tell it is a model 80 and a 2.250" post. From the one sales ad I was able to find (posted on this very forum) it's the "high end" Model 80 one too. I'm really impressed that after all these years only three original pieces are missing and there's no damage at all to the press. I shouldn't have too much trouble tracking down a proper motor, but the one that's on there now will work, just need to rewire it.
ryclo
Love this thread, very nice drills...
I was going to buy a Harbor Freight benchtop drill press but saw an old craftsman on craigslist for $20 and had to give it a shot. I am not sure what I have but its solid and heavy and I really like it! It jumps to the left when I drill something so I may need to rebuild it with new bushings/bearings (hope the spindle is not bent)... Anyone have any ideas how to take out the spindle? This one has a craftsman badge but a dunlap 1/3hp motor on the back.
jakemac
New England
Don't worry about the mixed branding on your new DP. Many Craftsman power tools of that era were sold without motors. That allowed the buyer to choose different power options, as well as different price points for the the motors. Dunlap was Sear's "economy" line for that time period, but there is little difference in the quality from the Craftsman line. I'm not sure, but the biggest difference may be bushings vs ball bearings in that motor (?). Another member would have more knowledge about it than I would. Either way, it should be a good machine once you have it up and running. It looks like a Model 80 or perhaps a Model 100. The diameter of the post will tell.
For $20 you did well (dare I say it's in the suckage range ?), and will have a DP that will last much longer than anything you would have picked up at HF.
ryclo
thanks, I will measure the post when (if) I get it apart. One other question, the handle you use to lower the spindle slides all the way out, how do you keep it in the middle? I didnt see any set screws or anything to lock it down?
The lever on the left front is the "clamp screw" for the spindle position. If you look there is a slot and the screw closes the housing on the outer spindle dia.
ecotec
The November 1949 parts price list says that feed handles are 50 cents each and feed handle balls are 30 cents each. I better call Kalamazoo and order them before the prices go up.
exmaxima1
Midwest
Last week i got this Atlas 1010 for $75. It is missing 2 feed handles and the balls that go on them.
What is the length and diameter of the handles (both the shank and ball diameters)? I have a pair of handles from a Delta DP600 that might fit. They are 7/16 dia shanks.
ryclo
Thanks, I am talking about the solid arm that you pull down to lower and raise the drill while its running to drill holes. Its just a solid bar with tiny grooves in each end and it slides into two holes but it falls out when in the vertical position. It seems like it should stay centered?
nine4gmc
Dallas
ryclo, there is a hole in the end of the shaft that the handle bar goes through, there was a bolt with a finger pad instead of hex head that goes in there to tighten against the pull bar so you can easily set it at any length through the shaft for perfect leverage. :beer:
Good find ecotec, mind getting a good clear pic of the sticker on the front of the head?
67carl
California
Can you find a model number plate on it anywhere or other numbers? Mine has one on the base - see it in the pic below on the base, near the shaft.
67carl
California
Also, here's a link where a guy did a total resto with pics and details that I've bookmarked for when I get to mine (thanks jbvinbal... something something. Can't remember the rest!)
http://www.garagejournal.com/forum/showthread.php?t=146523&highlight=craftsman+150+restoration
And another helpful thread:
http://www.garagejournal.com/forum/showthread.php?t=51384
There is also a site where you can download a pdf of the original owners manual but for some reason I didn't bookmark that and can't find it. If you can't find it and would like a copy of the owners manual PM me with your email address and I'll send it to you.
softailgarage
Bullhead City, Az.
A buddy picked up this Chicago Tool Company press for free, asked me to get it running, which I did. I'm dying to restore it, but he said I didn't have to. Well, I started to clean it up anyway. By the time he comes to pick it up, I'll have the chrome shining like new (Hehehe). I really, really dig the crank up table, i gotta get one.
ryclo
thanks for the heads up guys, here is a pic of the model number and a pic showing what I am taking about (circled in red). There is not hole for a thumb screw to hold the bar in any spot?
One other question, can the depth stop be changed out to a normal column style? Mine has a little allen head set screw you tighten on a ring which seems to be more work than needed vs the other style??
ecotec
Exmaxima1, the diameter of the feed handle is around 3/8", the OAL of handle and ball is 6 1/4", 5" of handle is hanging out of the ball, the ball's diameter is about 1 1/4".
I do not have a caliper. I used a tape measure.
I should probably get a caliper.
nine4gmc
Dallas
Ryclo, my bad. My model 100 has a threaded hole in the end to put a thumb screw type bolt. :dunno: You can change out the stop nut to a standard stop nut and toss that set screw collar in the parts bin. Also, you could find a standard bolt that fits in the set screw hole and weld the open end of a Craftsman ignition combo wrench on the bolt for easy access. I did that as a back up for a member the other day that I made a stop nut for, wish I had taken a pic).
nine4gmc
Dallas
Ecotec, super thanks! I thought it read something about "bearings" but could not make it out. :beer:
ecotec
Nine4, glad to do it. I will be careful with the decal when I finally get around to cleaning it up. It works so well, I just pressed it into service. For $75, I got a 65 year old tool that still works great back into service. I am really happy with it.
exmaxima1
Midwest
I think my handles are a tad larger:
Ball = 1.35"
Shank = .437"
Length of shank = 5"
