Show us your cool, "old" drill press
Gene_Blackman
Central MA.
$20.00 from a coworker
Before,
After
The only new part is the drive pulley. The one pictured is too small and has since been replaced.
(I know the clamp is installed in the wrong spot)
Sent from my Nexus 7 using Tapatalk
paulm12
NW Chicago 'burbs
just picked this up, don't know much about it yet, other than when powered on it trips the circuit breaker in the garage. Starting to look for manuals, etc.
paulm12
NW Chicago 'burbs
anybody recognize the brand? I can't find anything so far? thanks
Squashfest81
Swindled $15 off a GJ member last night, so I jumped on this when I saw it. Power King, 40's, runs smooth. What pulled me in was that it was a floor model, but little. Would it have been sold as a floor model? its silly top heavy, like won't stand on its own, so I'm guessing someone added a longer tube. And the wooden block, to attach to the ceiling is a clue. Now I need to figure out a broader base?
Squashfest81
Knocked the wood block off the top of the post. Yup, it's a 79 inch long 1 5/8 inch solid steel rod. I'm thinking that it's not original and the reason it won't stand up on its own. Plan is to chop it at like 42 inches? Taller than my 40's Craftsman/King Seelly, but workable.
nine4gmc
Dallas
Squashfest, I restored a bench model about two years ago and sold it or I would get you some measurements. I would probably save the solid pole for a unrelated project and find a hollow pipe that fits and keep it short, it was definitely a bench model to begin with.
Sent from my iThingy using Tapatalk
paulm12
NW Chicago 'burbs
Paulm12,
It looks like your drill press is a Shop Master. I just found these pictures and don't know anything about it. Hope this helps.shop master.jpg
thanks Charger. I had noticed that the DP-600 looked similar to mine, but I could not find the "Sm" logo anywhere. But looking now on the vintagemachinery site, there is 1 picture with a model number (DP-503) that is identical on mine, same number, same location, same font, etc. So I think you are right.
Do you have a soft copy of any manuals? thanks again.
Squashfest81
Nice investigation 66Charger.
Nine, oddly enough I grabbed this ancient Companion drillpress off the side of the road a few years back. It has a homemade front pulley made of wood that does not function, but it does have a 1 5\8in tube. So... Toss the Power King on it? She would be cute, but I fear that I would drag a 7ft 75lb solid rod around for the next 35 years.
Squashfest81
Did Shop Master make a Shopsmith knock off? I'm not sure, but sounds familiar.
I know of a Total Shop and a Wood Master. It all sounds similar. Did find a Shopmaster Universal tool based on a radial arm saw. Google Shopmaster cu6000 as I couldn't link.
Pretty cool. Let the hunt begin.
tombell572
Sea Cliff, NY & Portland, OR
<a href="http://s251.photobucket.com/user/Riderusty/media/Machines/Ebay022.jpg.html" target="_blank"><img src="http://i251.photobucket.com/albums/gg304/Riderusty/Machines/Ebay022.jpg" border="0" alt=" photo Ebay022.jpg"/></a>
This is my Snyder "camelback". The picture was taken before I installed the motor. It's now up and running using a Century 220v motor of appropriate age.
zkling
Beautiful and functional piece of machinery you have there. :drool:
E12-535iTurbo
The Netherlands
Is anybody familiar with Renner Drill presses? There is one for sale locally and inspired by A_PMech I'm considering it. There is not much information I could find online but perhaps I'm not looking in the right places.
It's built in Germany by the Company Renner from Dresden in 1970. Uses a belt drive and has rather low speeds from 125-500. But with a VFC or other transmission that could be changed. I already have a small bench mill capable of higher speeds and I'm looking for something that has power and low speeds for larger holes etc.
It's similar to: https://www.maschinensucher.de/Saeulenbohrmaschine-Renner-Dresden-B350/i-1712869
or:
Are there any particular things to check? I've contacted the seller and have a look at the drill tomorrow morning.
Squashfest81
Pulled the Power King and the old Companion apart. The Power King does look cute on the correctish post.
And beside her partner waiting for a location to present itself.
And the spares. Anyone? Oh, and a silly 7ft solid steel 1 5/8in rod with base.
Squash, you can put the "spare" table on the column and swing it to the back. then use it for holding "stuff" (Indexes, etc...)
To bad you weren't closer, I have a small column DP that needs a table.
E12, look for any slop in the bearings, (drop the quill down some to do that; and wear on the quill itself when not against a stop.)
E12-535iTurbo
The Netherlands
Thanks Outlaw. I bought the drill. I will pick it up later this week so hopefully I can post some pictures next week. It's in need of a serious cleaning. It's quite a bit older then I thought. Probably closer to 1920 than 1970 :). It was passed on in one family from father to son a few times. The new generation had no appreciation for it and I could have it for my initial bid of 75. To be continued...
Bellaireroad
Fort Worth
Just got this home to Fort Worth from Missouri. Interestingly, it started out in a refinery in Fort Worth that is now closed :)
S4cruiser
NC
So close! Just need a shorter belt for the motor side pulley.
Also picked up a table lift from JZiggy :3gears:
RHJO51
Red Hook, NY 12571
Hello All, I just picked up a nice old Atlas #73 drill press off CL. Seems to be in great shape, just missing the spindle cover (anybody have one?). Previous owner painted it nice holloween colors. Runs nice, but I'll be taking it apart for cleaning and paint. Can anyone till me if the collar that hold the depth stop is original for this DP? The parts list I've seen for the 73 has a half collar. Can anyone ID the motor? Looks like a Delta 1/2 HP but hard to read the label.
RHJO51
Red Hook, NY 12571
Meant to ask, the spring in my quill tension knob is fine and I tuned the knob a few times to increase the tension. However when I pulled the ratchet pawl knob, it released all the tension and now I can't really turn the knob. Spring is fine but tight together on the outside edge. Is there a way to fix without taking the whole thing apart? Thanks.
McBrownie
Cleveland, OH
Nice drill press, but can't say the same about the colors. :spit: Can't wait to see it cleaned up. Here is a similar label.
Tedley
Coastal MD Delmarva.
AMT Radial Arm Drill Press. They made/marketed their tools on the economical end of things but economy back then wasn't tin and plastic from China. By 1974 this Drill Press had been changed to include the return tension spring in the handle-shaft, as opposed to at the FAR ENDof the travel cable mechanism this one has(cable travels through the pipes and connects to a spring attached all the way back at the motor mount). I think somehow the quill is locked in a shaft it should spin freely within and my pulley wheel belt and all travels up and down as I use it. I'm pretty sure from pictures I've seen it's not supposed to be like that... But I'm gonna one day pour my soul into a much better Drill so I'm glad it works at all.
I found this old drill press in a hoarder’s front yard. It was tied to a bicycle and staked into the dirt with a piece of rebar. The entanglement was not only an effective way to lock up a bike, it worked to further lock any moving parts on the rusted drill press too. It had no motor. I gave the guy $20 for it and found a proper motor for $5. One month, laquer thinner, steel wool, wire wheel/brushes, machine oil picture wire brass crimps quarter inch plywood, hard oak from a pallet, some spray paint, MDF, t-nuts knobs and a lot of frustration later I have a new tool.
McBrownie
Cleveland, OH
Ted,
That is a nice piece of history that you have brought back from the brink. :thumbup: I really like the results. Do you have a "before" picture to share?
