Show us your cool, "old" drill press
schaffer970
Think I have finally figured out that it is a Model No 50 - looks like very early 30's. Advertisement for it attached.
Now I have to find the direct drive mounting hardware. One thing leads to another....
crguy
SW Washington
I'm not sure you're right about that. Your drive may well be the factory setup, and the ad shows the next model with the motor up high. Compare the head casting on yours to the one in the ad where the motor mounts.
I think Schaffer's DP is a "factory floor" DP, flat belts and all. The motor is not stock, and the head is sitting 180 out of phase. The flat belt would have gone to a set of pulleys that were on a common shaft for all the other powered gear on that line. possibly one engine possibly steam would have driven the floor/building. with the head design it would have been at the end of the era for that approach, as the head is, relative to the common shaft era, "Modern". You usually see the Camel back DS and even mills used here.
I would guesstimate that one is 1920's-1930's
I'm interested in a link to the "Delta's first DP" pic, as I suspect that is simply internet conceit, with no basis in fact.
Here is a camelback setup for the factory I described above:
The lower pulley gets driven by the in floor main drive shaft, and a clutch is used to engage the drive.
crguy
SW Washington
Lineshafts for that type of drill were usually mounted up high on the wall, or hanging from the ceiling. The 2 pulleys were "fast & loose" - one drives the drill press, the other just spins free on the shaft. The flat belt is shifted from pulley to pulley with the fork you can see in the picture. Just like an on/off switch. :thumbup:
crguy
SW Washington
Sorry, I think you're wrong on that. The OPs drill press has a factory V belt drive just like this early 30s Walker Turner #100.
Bear Creek Aviation
My Burgmaster Model B Turret Drill saved from the Scrap Man. 3 Phase, VFD powered. Had to go to the patent application to see how to repair it. Don't know the age, maybe 50's
Terry
zkling
Agree, the lack of motor mounting boss on the head caught my eye too, from the begining. I've seen that style before. Just haven't dug up the paper work on it.
Huh, I just realized that I never posted this here!
Those are a nice press, good overall size for general work. I like how they made the base into a 2nd table. Majority just leave a somewhat rough casting with two slots, no center hole. I have the craftsman version.
McBrownie
Cleveland, OH
Terry
That is really interesting. Are all of the spindles engaged at the same time or only the one pointing down? It would be one frightening machine with 5 spindles spinning at once.
BradnCali
This weekend, I found the long lost younger (and taller) brother to my 1944 bench top DP220. This floor model Delta is a 1948 that I'd found on Craigslist. The seller had several tools listed in the ad calling them out only "drill press", "two kinds of band saws", etc. He had no asking price; just asked for offers so I shot him a offer by text for $75 and forgot about it. This past weekend I got a response from him telling me I could have it for $100. The seller evidently inherited it from the original owner and had spent the last couple of years in storage. He plugged it, turned it on and it just purred! I got it home and removed the sacrificial wood from the table and underneath was a completely unmarred and rust-free table top! I don't think it saw the light of day since it was new! Anybody recognize what the light might have come from?
Brad
bubinga
It is designed to run only the active / drilling spindle..
Just picked up this cool looking Rockwell homecraft drill press for $75. These are the Craigslist pictures better pictures before and after to come.467cd461645048e2a0eaf95df23b7f17.jpgbcd9dd52211b86ec70e110be84687da1.jpg
Sent from my MotoG3 using Tapatalk
DanZ3
Pittsburgh PA
Just started "preserving" this Craftsman drill press. Since the paint is original I'm going to clean it up and use it as is.
McBrownie
Cleveland, OH
I like that idea. When the paint is that clean and original it would be a shame to strip it. Do you know who the manufacture is? Looks a little like a Delta-made machine.
:+1: WAY too nice to do more than clean and de-rust where needed.
A bit more light on the topic:
nine4gmc
Dallas
Here is a mod i just did on an old Atlas drill press table that was hard to adjust. The pole grippers would stay tight so i dug through my scrap bin and found these rocker arm springs. The inner support spring fits perfectly in between the pole grips and provides enough force to loosen the grip when you get ready to move the table.
Sent from my SM-T230NU using Tapatalk
nine4gmc
Dallas
Yes, the spring contacts the pole but it has plenty of room to flex so it does not affect it any.
bubinga
The spring clears the pole OK? Great idea...
yeah, i should try that on my craftsman, I always have to jerk it a bit after i loosen it.
Good Idea 94
CSFJ
near Flint, Michigan
Since I haven't gotten around to starting a thread for it yet, here's the press I picked up about a month ago. Before and after clean up and paint.
