lafester
Looks a lot like a delta base but not really worth saving.
Sent from my Pixel 3 XL using Tapatalk
Trying to find a good example of an Atlas Compound Cross Slide Table for the unit. Anyone have a line on places to find one, besides ebay?
Yes, but with the T vise.
Got a Jet 2500, didn't need to buy the old drill press. Don't need a large garage to put them in either![]()
That was an option on Canedy Otto's Royal series I think.
1967 Powermatic 1200 with a 1hp 3ph Robbins & Myers motor. I have not come across many like this online yet, which are the same style castings. I think the closest I came was a multi-gang industrial unit.
Here is my 40's walker turner 20" with power down feed i just finished up. would like to get a new base and a belt guard if someone has one laying around
thanks
That is a beautiful piece of machinery there jwallace. Did you do the restoration? Looks like a nice color match next to that South Bend.
Until recently, this 1959 Delta Rockwell 32” radial model had been my one and only DP. I’ve bored a lot of holes with it over the years. It’s a nice light to medium duty machine. It’s accurate and has minimal runout.
Jim C.
With the horizontal post intersecting the vertical post just a little right of center towards the head, it’s very stable and there’s no slop and almost zero runout. It actually drills a pretty nice hole. If I move the horizontal post in either direction much more than about two inches, accuracy of the holes starts to decline and there’s some vibration. If I push the head as far forward as possible to essentially make a floor standing model, the accuracy again is diminished and there’s some small amount of slop when pushing the bit into the workpiece. Almost like a deflection of the horizontal post. Like I said earlier, it’s great for light to medium work and is at its best when positioned as depicted below. I’ve had it for at least 25 years and I’ve been pretty happy with it as long as I don’t push it beyond its design limitations.
Jim C.
And you have the Retirement Light (with a paddle switch) an added bonus!
Matthew A.
Right! That light was on the drill press when I bought it. At the time I was just trying to get a hobby woodworking shop together. I was way more interested in the drill press. I didn’t even care about the light. It was a while before I realized the light was worth more than the drill press itself. I was lucky to later learn that the drill press is mounted on its original stand which is held together with correct bugle bolts and associated factory hardware. The cast iron table is in pretty good shape too. There’s a few small divots but no arc of shame. Like I said, I’ve been happy with it for a long time and I’ll continue to use it. But I’ll admit that my recently acquired floor standing drill press will see a lot more work in the future.
Jim C.
