48James
Show us your cool old drill presses!
Recently started to restore a very old delta drill press.
Enough with the jibber jabber. Now show us some drill presses fools!!
My 1921 vintage Buffalo. I'm gonna have to squirt some paint on it someday.
Very cool machine.
I notice Craftsman 150 drills are heavily represented here too. My grandfather used one in his shop for a number of years and it is still in the family. I've used it a couple times and it's a solid machine for its size.
Chuck, How did you add the new center pulleys?
Edit
Found this, might work: http://www.garagejournal.com/forum/showpost.php?p=667366&postcount=35
http://www.vintageprojects.com/machine-shop/LoSpeedPress.pdf
Here is my Silver Manufacturing 20 inch Drill press I recently restored. It still needs a belt for the powerfeed, but it functions. 3hp, with a #4 MT. I had to fabricate new bevel gears for the spindle, as the previous owner had broken them. Works great now. The pics make it look kinda pale, in person its a nice forest green. Here are some pics.
Does it have a self centering chuck with morse cone? The ones like yours that I've seen on our side of the pond has chucks were drill bit must be centered by hand.
Evintho, I take it that is the power switch shown below?
Mine has a pull chain like on an old table lamp.
Thanks,
Tony
Just got my newest drill in the shop this evening. In the first photo I have it hanging from slings to remove the shop brew coolant tray a previous owner put under the machine:
Here it is inside for the night. It will stay here for the near term, until I have a chance to pull the head, column and arm for overhaul. The little drill on the right is my first drill press, bought when I was 8 or 9 from the Cummins traveling tool show. Not a very good machine, but it served its purpose. I use it on occasion for coring holes in tile.
How much for one?2 1/2" al. bar stock, old alternator bearings, 5/8" shaft.
And a HF lathe
Chuck
Yeah that's the power switch. It originally had an old thumb wheel switch built into the power cord. Both were toast! I put in a new power cord and grabbed the rocker switch from Grainger. Had to bore a hole in the side of the head unit to make it fit but now it's much safer and cleaner.
Yeah, That's a clean job. I just had thought it was factory.
Since it had a switch in the cord, now I'm wondering if the switch on mine was put in by a PO or if it came like that.
Maybe they didn't have switches in them from the factory?
Ocular Engineer, did yours have a switch and what type?
Thanks,
Tony
They sold them with or without a motor. I suspect a lot of people bought them without, and then used a spare motor they had laying around the shop. My Craftsman has a switch in the cord, as far as I can tell it's always been that way but it doesn't have a factory motor either.
I've looked at the illustrations in the old Sears catalogs, and there's nothing to indicate one way or the other what they did for a switch.
It looks like those old Craftsman drill presses are pretty popular. I found mine in a basement of an estate sale. He is named Leroy for obvious reasons. The only thing I have done is replace the belts and add the cross vise.
what year are these things from ? i have one at my grand fathers wood working shop and i know its atleast 50 years old if not older
