Show us your fire pits!
JieselDeep
Captain Cook, Hawaii
From what I've read and experienced, the ashes will quickly eat through mild steel. The photo in the article you linked looked like a stainless steel barrel, not mild steel. Water run through ashes makes lye, a chemical with a pH of 13 (out of a Max of 14) and bases can be just as bad as acids with regard to reactivity with metals.
Just be prepared for it to get holes and to replace it now and then. Don't put it on top of something flammable, like a wooden deck, and you should be good.
Our old burn barrels would only last so long due to the same thing happening to them.
Sent from my XT1710-02 using Tapatalk
CoogarXR
I just went up the road to the truck repair shop and bought a 20" semi wheel for $10. I set it up on some bricks. I have been burning in it for 7 years now and it's holding up just fine. I'll snap a pic of it when I get a chance.
Bert_
NW Iowa
That's similar to what I do. My rim is a 38"? band dual from a tractor, a band dual has no center so wood sits right on the ground. I also made an adjustable height rack for grilling.
I'd take a pic but snow is falling and the wind is blowing so you'll have to use your imagination
ole442
Way freakin too close to the city
This fire pit used to be about 35 feet to the left in my yard. after I had my 24 X 30 garage built, it was to close so I moved it to the right.
Skunkape
Oklahoma
Just an old tractor rim, with pavers around it.. If I had to do it over, I would have buried the rim deeper, and only gone with 2 rows of pavers. When your sitting in front of it, its too high, and you only get heat from the chest area up... Another one of my typical failed projects... Lol
PNWguy
Near Grants Pass, OR
i picked up a 55gallon drum, and have been thinking about turning it into a fire pit for the backyard, anyone have similar projects? i'm looking for ideas how to make it happen
was thinking something like this
http://bestfirepitideas.com/barrel-fire-pit/metal-barrel-fire-pit/
I've made a few fire 55 gallon barrels. They work fine for a few years, then rust away. If you enjoy making them, and the barrel is cheap, go for it.
Make sure to put some air holes near the bottom or it won't burn well.
Oldbear
Linden, Alberta, Canada
Picked it up at a local garage sale. Welded some tabs to keep it from moving. We sunk to bricks into the ground and modified a different fire pit top.
ConCretin
Central Maine
Well if I'm gonna build a fire pit......
You knew it was gonna be concrete.
I built this 5' diameter fire pit last summer. Installed a drain and filled it with stone so it wouldn't become a swimming pool. It's big enough so the heat doesn't bother the concrete and you can sit or rest your feet on the rim.
Northislander
Vancouver Island
Only picture i have of my firepit at the cabin. Is this high water event with no fire but it does show the approx 60" diameter 1800 pound former cone from a rock crusher
Ole Slewfoot
Freedom, CA
An inquiry to the local authorities told us you can have a recreational fire in your firepit pretty much any time so long as the fuel is below the rim.
So the Excavator dug a hole 15' deep and 15 wide. The dirt was heaped around the rim like a mini volcano and planted with tropical plants. You know, in case we put too big of a tree in there. Well actually 2 trees was usually about right.there was a fire station pretty much right next door, so they saw the 40' flames out the top of this thing and came right over.
Fireman;" WTF is wrong with you people, you can't do this."
Resident; They said if our fuel was below the rim we were OK."
Fireman;:headscrat, " I hadnt really thought of it that way. Thats pretty cool, feel free to call us if you have any trouble."
Resident; "Thanks, do you guys want a beer?"
Somebody got a little too gung ho lighting it one time, and had a bit of a fuel air explosion. Not only did we blow out 17 windows, but the glass delivery guy didn't heed the warning about going slowly up the bumpy driveway, and broke almost every one...twice! But the mean neighbor lady took offense and sued us for disturbing the peace with 'loud and mysterious explosions'. Luckily she couldn't prove anything.
If there had been digital cameras then, we probably would have been screwed.
bruceu
Wow, well done - that looks great!
FTWingRiders
Central Ma
One of my wife's biggest request when we did the backyard over was a good sized fire pit, the guys will have this one cranking.. :beer:
The second gas one under the pavilion is more for ambiance and a little heat on a cooler night for the women. :thumbup:
classic boost
canton, oh
i made one at work from some scrap stainless. if i had to do it over, i would've made it lower & wider.
BuffettFan
Central Illinois
Ole Slewfoot, Your post is FUNNY!
Agreed!
At our old boat club in the middle of no where, we buried a 6' diameter concrete culvert 6' in the ground. We would go through 2 or 3 truckloads of wood a night.
We did have 2 rules though.
1.) It had to shake the ground when you lit the fire,
2.) The fire had to be visible from outer space.
We were careful to stick to the rules.
Northislander
Vancouver Island
That's beautiful enough to enjoy without any food or adult beverage:beer:
Hard to drink with a fly rod or tools in my hand. But once in awhile i sit and relax and down a cool one and enjoy. Cabin is finished now so its on the market and off to build the next one. Dug the hole in 2004 and finished last year so not exactly the quickest builder but its been built on weekends.
Hope the mods. don't mind but here's a link to the listing a few more pics. of cabin
http://www.bcoceanfront.com/listing/upper-campbell-lake-42722-gold-river-hwy/more-photos
garagelogician
Blaine, MN
I'm planning to do something like this, though I will probably cobble it together myself vs. over-paying for a "kit."
How close are you guys placing your fire pits to your house/shed/other wood structure? I'm trying to figure out a location that is out of the way but that still looks good and makes sense in the yard.
